Question about GE Marquette Eagle 4000 Vital Signs Patient Monitor with Ecg Nibp SPO2
I have problem that eagle 4000 monitor restart again & again..i have 4 unit (GE Marquette Eagle 4000 Vital Signs Patient Monitor with Ecg Nibp SPo2),& all have same problem.
Posted by jamshaid akram on
takhsaiti abdelouahed
    New Friend:
I have the same problem, i think you should update the softwere
Posted on Nov 21, 2013
1 Related Answer
Anonymous
  • 71 Answers
SOURCE: Troubleshooting GE Marquette Eagle 4000 Vital
I can help with these. I also have user guide and service guide. [email protected]
Posted on Sep 14, 2009
Requiero diagrama de fuente de alimentacion
you can visit this web and you can download service manual for eny devices : http://www.frankshospitalworkshop.com/equipment/ecg_service_manuals.html
Aug 29, 2013 | GE Marquette Eagle 4000 Vital Signs...
My eagle 4000 is 120volts then it is accedentally plug in to 220volts. it blown the fuse at the power supply pcb board then i replace the fuse 10amperes but it still blowing.what could be the problem?
There will be an MOV (metal oxide varistor) After fuse. This MOV is rated 125v. When you plug the machine in to 220v supply this MOV will become shorted and its blows the fuse to prevent further dameges to the power supply. Replace the MOV and then insert the fuse. I have added the image of MOV here. It is placed parallel to the AC mains supply rail after fuse.
Ajin
May 04, 2012 | GE Marquette Eagle 4000 Vital Signs...
Simultaniusly on and off
hi,
You have to check the battery of you monitor . If the battery is short then this problem can occur.
ok
Aug 03, 2011 | GE Marquette Eagle 4000 Vital Signs...
I need the service password to reset the unit to factory defult setting
hi,
remove the AC power. then remove the battery from the machine. reinsall the battery after 15 minutes. then power on. it will be at factory settings. if u need its service manual pls contact me through fixya . for removing battery watch the pictures bellow.
ok
Jan 09, 2011 | GE Marquette Eagle 4000 Vital Signs...
It keeps rebooting
when the battery goes completely dead it looses its software. The only way to fix this is if you have a copy of the original software and install a new battery. With these units it is a good idea not to leave them unplugged for a long period of time. It is a good way to loose all the data.
If you have further questions you can contact me at [email protected] or through our website www.overstockme.com. We have a biomed on staff with 25 years experience who is able to fix this issue.
Jul 14, 2010 | GE Marquette Eagle 4000 Vital Signs...
I HAVE AN EAGLE 4000
Most likely a bad battery which made the system loose the software. Small chance that the screen is bad. If you connect a pulse ox and you hear the hear rate it is a bad screen. If you don't hear it you will need to get a copy of the software and a new battery. GE does not support these anymore so you should contact a third party if you are not able to do it your self.
Jun 29, 2010 | GE Marquette Eagle 4000 Vital Signs...
I have a monitor marquette eagle 4000 no work with batery pack
After the battery goes dead in these units it earases the internal software. You need to have the software reinstalled with is a rather tricky thing to do.
Apr 20, 2009 | GE Marquette Eagle 4000 Vital Signs...
Changing display screen time
I have a user guide to help do this if it is still nessesary.
Mar 05, 2009 | GE Marquette Eagle 4000 Vital Signs...
GE Marquette Eagle 4000 Vital Signs Patient Monitor with Ecg Nibp SPO2 Logo
443 people viewed this question
Top GE Medical Experts
Marvin
Marvin
Harrie
Are you a GE Medical Expert? Answer questions, earn points and help others
