Question about Kodak ESP5250 All-In-One InkJet Printer
Error code 3604 Cartidge not recgnized
I used a Home depot brand made for kodak. I need to over ride error code 3604
Jim Gardiner
    New Friend:
Easy Solution. Dont buy Kodak. I did and they drove me crazy. I bought a Brother,,,great. and no chips on cartridges to carry out big brother ops.
Posted on May 23, 2013
4 Related Answers
Anonymous
  • 295 Answers
SOURCE: I have a kodak esp9 on win xp wireless connection.
  1. From your computer, access Device Manager.
    • For WINDOWS XP OS:
    • Right-click My Computer, then select Properties.
      • Select the Hardware tab, then Device Manager.
  2. Select View > Show hidden devices.
  3. Select Printers.
  4. Select Action > Uninstall.
  5. Select Action > Scan for hardware changes.
  6. Double-click the KODAK AiO Home Center icon. If the error occurs again, go to the next step.
  7. Set administrator rights for the Home Center application:
        • Right-click on the Home Center icon.
        • Click Properties.
        • Click the Compatibility tab.
        • Clear all the check boxes.
        • Click Apply and OK.
    1. Double-click the KODAK AiO Home Center icon. If the error occurs again, go to the next step.
      IMPORTANT: In the next step, before you install the Home Center Software, make sure you disconnect the USB cable. Then, connect the USB cable when the software installation instructions tell you to do so.
    2. Upgrade the software and firmware for your printer:
Posted on Jul 28, 2009
Anonymous
SOURCE: I get Home Center error code 1-2010 and cannot continue.
Sorry I don't have a solution! I have the same problem & have been having other problems with my ESP3AiO - like it shows that the ink cartridges need to be replaced when I just printed a few pictures with brand new cartridges, also gave error messages sayint the print head was missing when it wasn't & had been working fine! I'm frustrated & fed up with it!!!!! This is actually my second one!!!! The first one stopped working when it said there was a paper jam & there wasn't but it would not reset or do anything else!!!!!!!!!! Good luck with your situation. I'm heading out to buy another printer that won't be a Kodak!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Posted on Aug 09, 2009
Anonymous
  • 214 Answers
SOURCE: just bought Kodak ESP 3, all in one printer I'm
Try turning off the printer then restart the computer then try again
Posted on Dec 29, 2009
Anonymous
  • 7 Answers
SOURCE: keep getting error 2075 when i try to use the
Even i faced the same problem once, spent a lot of time talking with kodak support, it finally been solved. One of solutions they gave me takes effect, just delete all kodak files under "c:\users\<your user name>\appdata\", try it.
Posted on Apr 08, 2010
Hp desingjet 500 plus 24"
code error error 21:10 for hp designjet 500 24''
My hp 4355 printer, error code cartridge error, n
No problem ... just try to follow these steps please and it will give all the answer for your question
remove the cartidge from the printer and clean up the bronze dotted spots on the cartidge as well as the place where the cartidge is placed inside the printer... then turn on your printer it will ask you to insert the cartidges .....
hope it will owrk for you if does not you may try another cartidge if does not work either its time to call the Manufacturer and get the printer replaced....
6helpful
2answers
Line:44char:8862 error:handler already exists. what can i do?
When opening the kodak home center got an error.
it is a scanning error............ scanning usually take 1-2 minutes to scana document. make sure dat u've proper ink in ur cartridges. contact [email protected] 1800 21 6699 for further issues.
Error code: 1-2036
go to Kodak easyshare support:
http://www.kodak.com/global/en/service/products/ekn026079.jhtml?CID=go&idhbx=easyshareswsupport
In the box under Find Answers, type the complete error code (without spaces), then click Search. An error code should be like 12x413x1304x
Cheers
เสียงไม่มีทำไงช่วยด้วย...
this maybe an adress error or alacation error, what in your make and model and national laungage.
or the memory parity error, try 1 stick of ram restart machine, than try another un til you dont see the message again.
my call techincailsupport and talk to service techncain and ask them explain the code to you.
acer may able to assist you better with these issues
rod
Kodak ESP5250 All-In-One InkJet Printer Logo
Top Kodak Office Equipment & Supplies Experts
Ekse
Joaquim Martins
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
