Question about Lands Phones
No caller id display in utl81a phone, even if caller id facility is there.
I have BSNL landline connection with instrument of m/s united telecom limited UTL81A. My connection has Caller ID facility and it was functioning. But after some days it stopped functioning. BSNL confirms that the facility is still valid in the connection provided.
Patrick Demers
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 113 Answers
Call you local provider for help
Posted on Feb 09, 2016
5 Related Answers
Anonymous
SOURCE: No caller ID information for GE Caller ID phone ( Model # 29385GE1)
I must have gotten your unit. Mine did work ONCE after it had been installed for about a week. But it never worked again and we pitched it. Buy something else.
Posted on May 04, 2008
Anonymous
SOURCE: Uniden CXA15198 not showing caller id
Hi! There is a small device available in the market which is a converter. By connecting this between landline and phone, caller ID start display simply.
It cost to me Rs.450/- made by Fintel. Try to get it cheaper at your place.
Try this and the problem is solved.
Nrupesh
Posted on Sep 20, 2008
rylee_smith
Rylee Smith
  • 8619 Answers
SOURCE: UNIDEN TRU8888-CALLER ID DOES NOT WORK
Hi
Thanks for using FixYa. I think you have stored more than 100 Caller ID messages and hence the caller ID is not showing on Uniden Tru8888. In the following cases the caller ID will not be shown-
If you answer a call before the Caller ID message is received (for example, before the second ring), the Caller ID message will not appear.
When the call is received via a telephone company that does not offer Caller ID service, the caller’s phone number and name does not appear. (This includes some international calls.)
When the call is via a private branch exchange (PBX), the caller's phone number and name may not appear.
You may receive any one of the following messages:
When a private name is received; Private Name
When a private number is received; Private Number
When a unknown name is received; Unknown Name
When a unknown number is received; Unknown Number
When invalid data is received; Incomplete Data
The Caller ID list stores information for incoming calls - even unanswered calls. You can store up to 100 Caller ID messages and phonebook entries (including Speed Dials) for each handset and the base. You can view the Caller ID list through the handset or base during a call or when the phone is in standby mode.
Memory locations for Caller ID messages and Phonebook entries (including Speed Dials) are common, you can store up to all 100 entries for each handset and the base. Caller ID messages are not stored when you have 100 phonebook entries. When you have stored a total of 100 phonebook entries and Caller ID messages, the oldest Caller ID message is overwritten.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Posted on Aug 16, 2009
MNfisherman
Nate Stansfield
  • 11896 Answers
SOURCE: Caller ID not working on my t7316 phone
You can copy and paste this link below to go to a site where you can download your entire manual:
http://www.alphatelecom.ca/meridian_norstar_manuals.htm
Posted on Sep 16, 2009
Anonymous
  • 32 Answers
SOURCE: External caller ID does not display on either line talkswitch 284
Log into your TalkSwitch Management Software.
Go to Telephone Lines.
Under each incoming line make sure that Caller ID is checked.
Click File> Save
Hopefully this will fix it for you.
Posted on Jan 20, 2010
I wish to have incoming call number display
if its a landline directly connected to the exchange, you must register Caller ID with youre Service provider and it will show on youre phone (youre phone must be able to show ID,s)
Jan 19, 2015 | Lands Phones
Seimens Gigaset AL285 BSNL caller ID not working
The source of my caller ID not displaying was a faulty ADSL filter.
For some reason my ADSL filter blocked the caller id information - but worked fine otherwise.
When I changed the filter the caller ID worked fine again.
Jun 05, 2012 | Siemens Lands Phones
Caller ID not functional in Model KX-TG-9331T and 9332T
Do you have the converter that converts your caller id to U.S. caller id?
Mar 15, 2010 | Panasonic KX-T7633 Corded Phone
Could you please tell me how to set caller ID on my PANASONIC KT-TGA11OEX, thanks
is it caller id integrated phone then there is no need to set anything, rather than date, time etc... the incoming call no will show display.When call is coming and in display "NO CLIP" is showen then u must contact u'r service provider, to activate the facility. Some service provider give this facility by request...like BSNL.....
Sep 05, 2009 | Panasonic Lands Phones
Nrupesh
Apr 08, 2008 | Uniden CXA15198 Twin Corded/Cordless Phone
I don't think the problem is the FSK vs. DTMF. The manual even states that the caller ID is generally received after the second ring. This is true in America. I lived in India for four months and I never ran into the problem there so... I just can't say how your provider sends the caller ID. It may be that the line is being interfered with. Do you have a DSL line attached to the same device. If so make sure that there is a filter between you phone and its connection.
I am assuming that you tested your line with the other equipment connected to the same location. You may want to reduce the problem to the simplest configuration by connecting directly to the line only no other equipment. If it works add the other equipment until the caller ID stops again. Then you know what is interfering. If you have a monitor set you could listen to the DTMF being sent make sure it is coming between the first and second ring. It is audible if it is there. If you are answering on the first ring you will not see caller ID you have to wait till after the second ring then you should see it, If BSNL is sending the same as American systems. Good luck Z
Mar 12, 2008 | Panasonic (KX-TG1032S) Phone
Caller id not working
US phones use Bellcore FSK caller id. India uses DTMF caller id. Buy a DTMF- FSK converter at a telecom shop.
Jan 05, 2008 | Motorola Mobility 5.8 GHz Digital Cordless...
CALLER ID NOT WORKING
not only Panasonic, most other brand phones imported from other countries wont work in in India ( caller ID). Panasonic phones of Panasonic India, will work.I think panasonic has to explain this. if there are networks which does not support this equipment, atleast they should mention this is their booklets, to avoid users roam around telecom offices. To my understanding, all the land phones of BSNL through out India are caller ID enabled by default and is free!.
Aug 19, 2007 | Panasonic KX-TG2632W Phone
Lands Phones Logo
330 people viewed this question
Top Lands Phones Experts
Marvin
Marvin
k24674
Are you a Lands Phone Expert? Answer questions, earn points and help others
