SOURCE: code po480
Do both fans work for sure? You may want to replace the fans runs anywhere from 140$ up to 250$ depending on the brand.
Keep me updated.
Thanks,
Lee
SOURCE: check engine light comes on upon start up
alot of cars show a crankposition sensor on a test if it was bad car would not run unless you have a problem with car stalling or running bad when it gets hot not a ignition module if car still runs good not a major problem one problem would be a bad 02 sensor does not mess with car alot gas milage loss mabe slight hesitaion look at sensors that dont mess with engine if not 02
SOURCE: 2004 Dodge Ram 1500 Hemi Sport Quad 4WD
on my 2004 ram 2500, I had to depress the trip odometer button and turn on the Ignition. all lights on instrument panel will illuminate, continue to hold button in and tach/speedomenter will run full up and back down. once this has completed, the obd codes will be shown in the odometer.
Good Luck
SOURCE: code po705= Transmission range sensor, circuit
i ve run into this problem a few times,with no cler results,i checked all wiring from computer to switch and all check out fine i also replaced switch and a month later same code,this one ended up with a bad pcm, another one had a bad wiring for overdrive switch, this was not an easy repair to diagnose.i think you should have amazda dealer look at it.
SOURCE: ml350 replaced a/b cam position sensor reset
P0010....'A' Camshaft Position Actuator Circuit (Bank 1) P0011....'A' Camshaft Position - Timing Over-Advanced or System Performance (Bank 1) P0012....'A' Camshaft Position - Timing Over-Retarded (Bank 1) P0013....'B' Camshaft Position - Actuator Circuit (Bank 1) P0014....'B' Camshaft Position - Timing Over-Advanced or System Performance (Bank 1) P0015....'B' Camshaft Position -Timing Over-Retarded (Bank 1) P0020....'A' Camshaft Position Actuator Circuit (Bank 2) P0021....'A' Camshaft Position - Timing Over-Advanced or System Performance (Bank 2) P0022....'A' Camshaft Position - Timing Over-Retarded (Bank 2) P0023....'B' Camshaft Position - Actuator Circuit (Bank 2) P0024....'B' Camshaft Position - Timing Over-Advanced or System Performance (Bank 2) P0025....'B' Camshaft Position - Timing Over-Retarded (Bank 2) I think your sensors are pattern parts and the readings /resistances are not the same as the original parts ,try some bosch units is my first suggestion ,
