Question about Integra Audio Players & Recorders
How do I set up an Integra DTR 7.8 for 3D display and audio
I have purchased an Epson EHTW9000 projector and a Samsung BD5500 DVD player, both 3D devices. My receiver is an Integra DTR 7.8 and with present set up (HDMI from DVD player to receiver to projector) will not display in 3D format. I believe I can by pass receiver by hooking into projector directly from DVD player, but not sure how to do this and still get good quality 3D picture and audio, as well as play 2D DVDs without having to setup each time. I am not a technical person and will need this to be explained in laymans terms if possible. Thank You
Posted by Ross Graham on
  • Ross Graham May 18, 2012
    Thanks David! Your suggestion works. There was already an HDMI cable in the ceiling hooked into projector so just unhooked other end from the receiver and put into disc player. Then used co ax cable from player to receiver for sound. Works a treat for 3D. Have yet to try with 2D.
David Duncan
  • 760 Answers
Your DTR-7.8 receiver is not 3D compatible. It does not support the new 1.4 HDMI. You have to have 1.4 HDMI and 1.4 cables for the 3D format.
You can bypass your receiver for the video though. Simply run your HDMI cord (1.4) from your Blue Ray to your Projector. Your audio can be ran from your Blue ray to your reciever.
Posted on May 17, 2012
5 Related Answers
Anonymous
  • 4 Answers
SOURCE: Onkyo TX-SR705 - No Audio - Flashing HDMI
The posabilities is power amplifier on your reciever is bad,
replays reciever or repair it.More likely this is IC amplifier located on the main board of the reciever
Posted on Apr 17, 2009
Anonymous
SOURCE: no HDMI video output from AVR-588 receiver to plasma TV ???
You can also use a digital coax cable (color orange) to go into coax 1 for DVD coax 2 for cable box. Just make sure to set the coax in input settings. The coax cables are a little cheaper than the optical cables and work just as well.
Posted on May 10, 2008
SOURCE: Sherwood RD-7502 Hdmi Audio Problem
if you have a tv with outputs you can connect audio wires from your tv output to your audio receiver input and you will have surround sound for everything connected to your tv
Posted on Aug 28, 2009
Testimonial: "That's a good idea. I hope that my TV will output the hdmi audio through the optical output on it. Thanks"
satavlad
Alex Zoubkov
  • 405 Answers
SOURCE: Yamaha HTR-6230 receiver set up w/HDMI no sound
BD and DVR hooked up to the receiver and from the receiver to the TV right? If yes: Your receiver set to pass sound trough to the TV, if you want sound from the home theater setting has to be changed.
Posted on Nov 28, 2009
dunnbiker
David Dunn
  • 8546 Answers
SOURCE: I have an RX-V663 audio sounds flat
Let's deal with the turntable sound first - unless it's a self-preamplified model you would have to get an external phono-specific preamp to use with this receiver. Without one you'll get microscopically weak, tinny sound from the turntable. Google "RIAA curve" to see why.
As far as the CD sound through the Blu Ray player... for one thing it is flat, as in two-dimensional stereo. Compared to genuine surround from a movie it would be a letdown.
Can you better define 'flat'?
Posted on Feb 04, 2010
Testimonial: "Thanks for working on this with me, you really dove in!"
My integra av receiver model no DTR-70.1 amplifier displays but no sound what could be the problem?
http://www.integrahometheater.com/faqs.php Check the connections and try a master reset?
Perform a master reset. To do the reset you need to turn the receiver on, then on the front panel of the receiver press and hold the "VCR/DVR" button while doing that press the "STANDBY/ON" button. You will see the word "Clear" in the display screen and the receiver will go into standby mode.
Jul 03, 2018 | Integra Audio Players & Recorders
I am not getting any audio (sound) out of my Integra DTR 4.6. Any suggestions?
Does the vu meter show anything(bars moving up and down when audio is present?If so you may have a blown fuse or bad IC in the amplifier section causing the problem. If there is no indication of audio on the front panel it would be a Microprocessor problem
Oct 15, 2014 | RCA Onkyo Integra Dtr-4.6 Av Receiver Wrat
"handshake" between DTR 5.9 and an LG Blu-ray player
You will have a defective processor pcb. You may want to see if you can get Integra to give you a one time repair on this.
Mar 26, 2014 | Integra Onkyo Rc-711m Dtr-4.9 / 5.9...
Denon AVR-4806 HDMI problem
Check which port you have the HDMI cable connected to, then go into the menu on the TV, look for it on screen and Enable it .
Good luck
Nov 16, 2013 | Denon AVR-4800 Receiver
Integra DTR-5.6, no sound for am/fm tuner
reset receiver if that does not work You will have a defective processor pcb
Aug 24, 2013 | Integra DTR 5.6 Multi Media Amp
The reciver dosnt get a signal from the hdmi inputs both ps3 and blu ray have the same problem it is a dtr 5.9 integra
what you should do is make sure that your HDMI is cord is not in an awkard position, which like mine i have to unplug and plug back in to get a signal
Mar 01, 2010 | Integra DTR-5.1 Receiver
Doing a job for a friend. Reconnecting all his gear to an Integra DTR-7.1. Everything works except for the surround. I can't get the rears to speak from the receiver. I have verified they work (wires...
if you have everything connected properly, then it wont necessarily utilize ALL of the speakers, unless you have a true 7.1 signal coming in. is it using optical or coaxial? make sure that the options on the receiver are set right......the rears on 5.1 and 7.1 dont work unless they are told to by the receiver....and the signal coming in from the external source ( dvd player, ps2, ps3, xbox....) tell the receiver what it is going to need, in order to utilize the full signal. everything is labeled, and it sounds like you know what you're doing, when it comes to hooking this up, which is always good. it sounds to me, like something isnt configured properly, so i would start there. it may take a while, but you get the idea.....
Sep 24, 2009 | Integra DTR-7.1 Receiver
Low to no volume output from Integra DTR-5.2 receiver
most higher end integra's have a input level adjusment or input selection for each and every input. Perhaps you are not on the correct input, go to onscreen programming and check out the input level and input select - also try the tape in another input like tape 2 or cd. It will not hurt the receiver for a test. Also, if you are using the cheap cables from the manufacturer - try a pair of cables that you know work or go by some. BTW, you don't need to spend $40 for cables order them online through amazon or other store. Gold / sliver plated oxygen free are best.
Jun 30, 2009 | Integra DTR-5.2 Receiver
No sound from speakers from components with Integra 6.9 receiver
Turns out it had to do with one of the settings for the new Blu-Ray player.
Thanks anyway.
Jan 17, 2009 | Integra DTR-9.1 7.1 Channels Receiver
Epson Powerlite 1815p screen projector - DVD playback video jerkiness when there is motion in the video
I am assuming that the DVD plays normally on the display of the Dell 745.
Then the issue(s) may be with the:
1. Networking configuration/set-up of the Dell and/or the Epson;
2. ethernet cable;
3. configuration/set-up of the projector or the Epson itself.
A couple of things you can try:
1. Optimize your networking throughput.
1.1 Increase your PCI Latency Timer to 128 or 255 in the Dell's BIOS/CMOS setup (if present);
1.2 Try running DRTCP.exe and/or TCPOptimizer.exe appropriate to the Dell's OS;
1.3 Disable all other networking activities on the Dell. This may include auto updates, security/antivirus checks, etc. while running the DVD;
1.4 Slim down Dell's startup programs to bare minimum;
1.5 Increase your OS' swap file to roughly double your onboard memory
2. Try running a hub midway between the Dell and the Epson.
3. Verify that it is not the Epson that is problematic by playing a video source to the projector’s Video or S-Video port. If it is, then you have narrowed down the problem to the playing capability of the Epson.
Alternately if all else fails, perhaps you can try using:
1. a DVD player to the projector’s Video or S-Video port; and/or
2. a USB external DVD drive or a CompactFlash card (with a copy of the movie) direct to the 1815p
while settling the main issue.
Hope this be of help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Jan 07, 2008 | Office Equipment & Supplies
339 people viewed this question
Top Integra Audio Players & Recorders Experts
Andrew Taylor
Andrew Taylor
Larry Stiles
Larry Stiles
Are you an Integra Audio Player and Recorder Expert? Answer questions, earn points and help others
