DVD RAM change to CD Rom when i inset a disc
My DVD RAM can't read/play/write DVD/CD. When I insert a disk DVD-RAM Drive (E:) automatically changes to CD Rom (E:)
Posted by Ckrabby Patty on
  • Ckrabby Patty May 16, 2012
    HL-DT-ST DVDRAM GH15
Victor Lee
    New Friend:
Check your computer drivers for that drive. It may be a driver error. It has happened to me before and I fixed it by reinstalling the drivers. It should be a software issue if you can still read CD disks.
Posted on May 16, 2012
    can't even read a lens cleaner. what do you mean check the drivers? xp automatically detects that drive even if I uninstall it.
  • Victor Lee May 19, 2012
    Every disk drive will have a windows driver that allows the system to automatically run the program. It maybe the one that comes pre installed on your windows system may have become corrupted. Most drives will have driver downloads from customer support at the company website. Just download and reinstall the driver.
1 Related Answer
Anonymous
  • 2110 Answers
SOURCE: CD not being read from CD/DVD ROM Drive on Laptop
try to clean the cd drive lens with a lens cleaner...
Posted on Jan 30, 2009
It will not play Verbatim DVD-R disc that I burnt on my computer.
If it can read any other disk, you should burn your disk again because burning process was incorrect. your computer can't recognize the disk. In this case, probably you can't do anything, no way to try to read a bad disk if computer can't even "see" it.
By the way, you should test to read the disk on some other computer.
If happens with ALL your disks, your optical player is defective.
Again test reading with other computer if record was made correctly
As for your device, you should check if worth to repair and decide if repair or replace it.
How to Replace DVD CD Drive in Computer Tower
How To Install Computer CD DVD or Bluray ROM Drive Ep 7
Replace Laptop DVD CD Optical Drive Complete Tutorial
How To Replace the Optical Drive HP Pavilion DV6 Laptop HD
1helpful
3answers
Can't watch blue ray movies on my acer aspire model 5334
Taken from the acer support website.
" Optical media drive 8X DVD-Super Multi double-layer drive:
  • Read: 24X CD-ROM, 24X CD-R, 24X CD-RW, 8X DVD-ROM, 8X DVD-R, 8X DVD+R, 6X DVD-ROM DL (double-layer), 6X DVD-R DL (double-layer), 6X DVD+R DL (double-layer), 6X DVD-RW, 6X DVD+RW, 5X DVD-RAM
  • Write: 24X CD-R, 16X CD-RW, 8X DVD-R, 8X DVD+R, 4X DVD-R DL (double-layer), 4X DVD+R DL (double-layer), 6X DVD-RW, 8X DVD+RW, 5X DVD-RAM
This model of computer does not have a blu-ray drive unless you got a third party upgrade. In this case, you will need to track down special drivers, which can best be done by whomever sold you the drive.
I cant play the game an error says No disc inserted. Please insert the original "NBA2K11_EU" CD/DVD
Does your CD/DVD reader successfully read any *OTHER* CD/DVD disks?
If not, it is broken, and needs to be replaced.
If the drive works, then Insert the original 'NBA 2011' CD/DVD disk, when prompted.
I put in a blank cd and I cannot burn it because in my computer it shows that there is no cd inserted
Here you go...I hope this works for you....
CD/DVD Is Not Recognized
spacer.gif spacer.gif spacer.gif spacer.gif Many times, after inserting a disc into the CD or DVD drive, the disc is not recognized by that drive. CD-read and DVD-read issues can be caused by many sources. Perform the procedures presented in this General Computer Advice article when troubleshooting CD-read and DVD-read issues.
Begin with the first procedure and continue through the list. Try using the CD or DVD after each procedure is completed. For any procedure that requires changing current system settings, record the original settings before completing the procedure.
  1. Verify that the correct disc (CD/DVD) is used when prompted to insert the disc.
  2. For programs on DVD, verify that the drive containing the DVD is a DVD drive and not a CD-ROM drive. Most DVD drives will haveDVD printed on the front of the drive. For programs on DVD, consider the following:
  • DVD drives can read both DVD's and CD's.
  • CD-ROM drives can read only CD's.
  1. If multiple disc drives (e.g., CD-ROM and CD-RW, or DVD and DVD-RW, or CD-ROM and DVD-RW, etc.) exist on the computer that can read the disc (refer to the items under Step 2), insert the CD or DVD into the other drive and try the program again.
  2. If you are attempting to install a program and the installation does not begin after inserting the CD/DVD into the proper drive, refer to the program's instructions for the installation procedure.
  3. Clean the CD/DVD in the following manner:
  1. Place a small amount of nonabrasive liquid soap on the shiny side of the CD/DVD.
  2. Using your fingertips and warm water, gently rub the soap on the CD/DVD in a circular motion.
  3. Rinse the CD/DVD thoroughly and dry it using a clean, soft T-shirt or lint-free towel. (Do not use paper towels or tissue paper.)
  1. Try to use a different CD or DVD in the drive to see if that disc can be read.
  2. If possible, insert the problem CD or DVD into the DVD or CD drive of another computer to see if the issue persists.
3answers
3helpful
My laptop cd/dvd can't read disc when inserted
may be your cd/dvd rom is weak. replace the dvd rom.
2answers
Magnavox DVD Video Player DVD609AT
DVD609AT:
The manual is available at Philips website, the number for more info in manual is out-of-date; the new number is 1-800-605-8610
This unit has a problem when playing dual-layer discs of some kinds - read the warnings on the Magnavox website - playing the wrong kind of disc will cause an error that will require svc/repalcement to fix
Playable Discs
This DVD Player will play Digital Video Discs (DVDs) and Audio CDs. In order to play a
DVD or Audio CD on this DVD Player, make sure the Disc meets the requirements for
Region Codes and Color Systems as described on this page. Also, the Discs should have
the following logos and should meet these standards.
• CD-ROM
• Compact Disc-Interactive
(CD-I)
• Compact Disc-Recordable
(CD-R)
• Digital Video Disc-Video
Recordable (DVD-VR)
• DVD-RAM
• DVD-ROM
• Super Audio CD (SACD)
• Photo CD
• Video CD
• Video Single Disc (VSD)
Digital
Video
Disc
12 cm
12 cm
Approx. 4 hours
(single-sided)
Approx. 8 hours
(double-sided)
Approx. 80 minutes
(single-sided)
Approx. 160 minutes
(double-sided)
20 minutes
8 cm
8 cm
(singles)
Logo
Maximum
Disc Type Contents Playback Time
Sound
and
Pictures
Audio
CD
Disc Size
Sound
74 minutes
Disc
Segments
DVDs are
divided into Titles,
which are divided
into Chapters.
Titles and Chapters
are numbered.
Audio CDs are divided
into numbered Tracks, i.e.,
a track may be one song.
Unacceptable Discs
If you insert an unacceptable type of disc, “Please insert a playable disc” will appear on
the TV screen. Also, “- - - - - “ will appear on the DVD Player display panel. Insert a
DVD or Audio CD. The following Discs will not play on this DVD Player.
• CD-ROM
(CD-I)
(CD-R)
Recordable (DVD-VR)
• DVD-RAM
• DVD-ROM
• Photo CD
• Video CD
Computers & Internet Logo
Ekse
