Bought a brand new ad card, formatted it and camera still says needs to be formatted...over and over
SOURCE: Won't format new memory card
Your camera is not SDHC compatible. It will only support standard SD cards. Sorry.
I hope this helps.
SOURCE: Kodak c310 camera won't format new SD 2GB card old card same size
Older C310s won't take that large a card. Try to exchange it for a 1 GB or smaller. I had the same problem - a PNY 1 GB works fine
SOURCE: I bought a 2GB SD card for my Kodak EasyShare C330 Camera
Buy a 1GB card (or 2). The spec for the SD card format is going to 2GB but the Kodak C330 not compatible with 2 GB SD memory cards.
Click
SOURCE: I bought my Kodak Easyshare C310 a few years ago
Hi there
Check to make sure the cards write protect is
off, take the card out of the camera, face the card towards you, look
for a small white tab on
the left hand side of the card, to unlock it push the tab down, it will
be at the side of the card like this . Put it back in the camera and use the menu to format the card.
If the format fails then its a possibility that you will need a new card.
Good luck and thanks for choosing FixYa!!
SOURCE: I bought a new sd
Insert the memory card. Press the MENU button. Use up/down to highlight Setup (three horizontal sliders) and press the OK button. Use up/down to highlight "Format" and press OK.
Make sure you're using an SD card. If the card is larger than 2GB than it's actually an SDHC card and won't work in the C330.
