SOURCE: I cant make calls on my Kx-t7730 but i can recieve calls
sounds like you need to call a qualified tech
SOURCE: Panasonic kx-TG2352 can not dial ,phone works for
Believe it or not, I accidentally discovered you have to really press hard on the numbers to dial !!! I guess this happened as one is used to a light touch working on a cell etc
SOURCE: how to block "0" for
As was pointed out to me, you could take a screwdriver and pry the 0 key off the tone pads :-)
Panasonic systems restrict calls by tables called Toll Restriction (TRS). It's a complete section in the installation and programming manual. It involves setting tables, usually in the 302-306 area, then picking a class of service for the phone that acts on the numbers dialed.
In the simplest systems, the TA series, you have 20 restrictions per class 2-5 and one 80 entry exception table. It's a little tricky to set up in that a COS-2 extension has all the restrictions in COS-2 tables, but a COS-5 extension has all the restrictions in COS-2,3,4, and 5 :-)
Your Pana installer can do this fairly quickly, but if you plan on doing it yourself, please read the TRS examples carefully.
Carl
SOURCE: Hi, I've just added and expansion card in my
No. At the very minimum, you need to go to program 400 (3.3 in the U.S. Maintenance Console) and turn on the lines. Access may have to be enabled from each extension for both outward and ringing programming might have to be added.
Carl
Testimonial: "thanks for the prompt response. "
