I have a Thomas Pacconi Classic Millennium Series model TPC-MSE-800. The radio and cassette player both work fine but the cd play will not play a cd. I can open and close the cd door. When I put a cd in the player you can hear it start after you push play but after a few seconds an E shows on the cd lcd readout and the player clicks off. The lcd play light goes out when this happens.
SOURCE: will not record
the classic cdr201 will not record it will go to wait and return to cd status(blank cd etc) there is no led display of sound during this operation you can hear the audio for brief couple of seconds before it goes back to cd mode
SOURCE: Not Recognising a CD
I got a second hand 541 a few weeks ago. After many hours of listening pleasure an no problems at all, the machine stopped spinning CD's, both copied ones and original ones.
The sollution for my problem was simple after some figuring out.
Open the CD tray.
Power off the unit with the tray open.
Open it up.
In the CD frame in the back there are 2 srews that hold the CD engine unit in place. I untidied these screws just a little bit.
I also untidied the screws that hold the cd clamp cover on the top a little.
After this it loads all my CD's fine again.
SOURCE: Can't close door of CD on Sony CMT-CP1
Mine had the same fault. The CD is being rejected as it could not load up - this is probably because of the CD loading mechanism.
You'll need to unplug and remove the case - 4 screws on the sides and 4 or 5 on the back. Once this is done plug back in (be careful not to touch any live parts inside), load a CD and watch. What you'll probably see is that when the drawer closes the mechanism under the drawer doesn't lift sufficiently. Give it small push when it tries and I bet it then will and the CD will play.
What you need to do to fix this is remove the front panel/PCB and also remove the plastic cover that is screwed above the CD drawer so that you can see more of the topside of the mechanism.
Remove the front panel/PCB by releasing the 2 screws on the bottom and then easing forward. Gentle - as there are pins connecting the front PCB to the side PCB. You should then be able to see a worm drive type arrangement that lifts the lower assembly. This will need regreasing (I used vaseline) with a small stick (I used a Q-tip with the bud cut off). You will probably see where the old grease has been pushed out. Once you've done this, reassemble and operate a good few times to work the grease in.
Done! Mine works fine now after sitting there performing the annoying trick you described for many months!
SOURCE: It wont play CDs
the cds you put in there are not compatible to the player.if it had been playing the same cds then it is time to take your set to a tech for repair it can be your memory chip or your lens.good luck.
