Baught a acer and cant reload the os how do i get that done
This is more fun than you can imagine but first you must decide which OS you would like whether it be Windows or LINUX. Windows is the more common option for most users, however LINUX is quite excellent just a bit of a learning curve at first.
Whatever you go with, I also recommend using a program called WinsetupFromUSBhttp://code.google.com/p/winsetupfromusb/downloads/list. It will setup a usb stick to boot many options, such as windows installations or linux os or both plus many more, I made a diagnostic bootable usb stick with 20 different boot options for installations diagnostic programs ect !
Hope that helps
Christopher
SOURCE: how can i reset my
turn on your machine then hit del b4 the system starts...go to bios setting and locate the "set to default setting"..if it doesn't help,follow these steps; (you need a flash drive to do this)
instructions:
1.Save any files or folders on your Acer Aspire One with flash drives. Drag and drop files onto the icon of your flash drive.
SOURCE: i need bluetoot driver win
you may download the bluetooth driver and all other drivers strait from the acer website at no charge
SOURCE: i have an acer aspire 5336. i want to know if it
If your system is capable of this it would be touted as a bonus...If it doesnt say anything about this in the manual or on a label on the system...you dont have it.....you can get this by upgrading your DVD/CD player..but it is not a do it yourself project..,, Good Luck
Testimonial: "Thanks, I was just wondering"
SOURCE: acer aspire 5336-2524 touch pad
Run a driver check on your system by clicking run through the start button and type dxdiag to check if your touch pad driver is still available or working. If it shows it is working, troubleshoot your system. If not, you can get a the driver by surfing via google or you can rerun your window. Also, you can get a better antivirus like avast.
SOURCE: My Acer Aspire 5336 needs
To run a recovery on a an Acer notebook, please do the following.
- Turn notebook off.
- Turn on and repeatedly tap ALT + F10 together.
It'll now load the recovery manager.
- Select 'Restore system to factory defaults.
It'll take about 30 mins to 1 hour.
Regards.
