After a not correct shut down my iconia don't start
Computer does not boot upThe problem maybe the RAM, it is faulty or just needsreseating to make proper electrical contact.
Reseat the RAM and then boot up your laptop. If it still does not boot up thenremove the RAM module/s and take them to your friendly computer repair shop andget them to test the RAM for you.
SOURCE: Mouse works, click on icon, nothing happens
its seems your os is havening problem try to restore to earlier date or repair it.
SOURCE: When I press shut down,
hi, when you press the power button it'll goes to sleep mode only. You can change it by accessing control panel -> power option...
thanks & regards
Anas K A
SOURCE: My mom owns an ASUS laptop, which we share. She
This could mean that the battery is dead. Make sure you have ac power connected to your laptop and that your ac power cord is working
SOURCE: Hello, my brothers acer 5800
get into the bios check whether the hard drive is detecting or not, make your hard drive the first booting device, then check............if this does not solve your problem try to re install the os again
SOURCE: how do I hook up my acer iconia tab a500 to the tv?
Hi Cari,
There is a micro HDMI port on your tablet.
You can connect an HDMI cable to hook it to your TV.
Make sure that the one end of the cable should be a micro HDMI plug and the other end a normal one.
Also you must make sure that your TV supports HDMI connection.
Hope that helps.
The tab appears turned on because windows logo is on
