Multiple sheets in paper feed section (jam code 21) Feed switch 3 (FSW3) of the copier and the desk feed switch (DFSW) do not turn off within the time required to convey the length of the used paper size plus 635 ms of turning on.
Elektrotanya for electronics experts
Service manual attached.
SOURCE: error code C-6 for kyocera km 1500
Fuser error,
may have either a blown lamp, blown thermo fuse or faulty thermistors, but more then likely a combination of at least two.
SOURCE: KM-3035 scanning issues
the 30/40/5035 series machines have two network cards in them. One for printing and one for scanning. and they have separate IP numbers also. make sure you have scanfile utility running on your pc or wherever you are sending the files and the folder set up in the utility. then set it up on the scanner network card.. Not the printer.
SOURCE: Kyocera 3035
Is the line appearing after the drum? After the fuser? when the original is laid on the glass to copy or fed through the document feeded? What kind of line? How wide?
SOURCE: Kyocera KM-3035 System Error C0240
this is a printer error
it sound like you tried to update the printer firmware with an unzipped file from an incorrect print system
you need to format the cf card on the PC first then you need to format it on the printer, you will see the card option when you go into the user printer menu. it is print system U
c6-400 code error is poor connection (power supply)
press start and clear/stop button
the code is inizialized
