Toshiba 61A60 TV Logo
Question about Toshiba 61A60 TV
Blinking red light toshiba tv model 61A60A
TV will not turn on. It has a blinking red light near the power button
5 Related Answers
snakehead
Henry Thomas
  • 1074 Answers
SOURCE: TV does not turn on; red light blinking.
your problem is a more technical problem you will need a tech to look at your set if you are not a tech you wont be able to do it your self. contact a tech to repair your set the problem is in the power supply or related circuit.good luck.
Posted on May 02, 2007
SOURCE: blinking light wont turn on Toshiba TV CE19H15
Yes, it's quite possible that you indeed may have sufferd from a Power Spike, induced by lightning during the storm, esspecially if plugged in during said storm. I have had quite a few customers ova the years with this exact problem. I always advise my clients to unplug ALL devices during a storm, and for ones that simply cannot be unplugged then some sort of Spike/Surge Protection device MUST be used. As a matter of interest, I have written many a report to insurance companies to support a claim for a replacement.
Posted on Aug 08, 2007
Anonymous
  • 1139 Answers
SOURCE: Won't turn on or off - red light blinking
This sounds like a power supply problem, visually check the fuses and if they look ok, and you have a backgroud in electronics test to see if the set is prducing Dc voltage, you will need a multimeter and a schematic to do this with. However, if you do not have a background in electronics please take the set to a qualifide TV repair shop to have the repairs done.
I hope this helps.
Thank you,
Shuttle83
Posted on Nov 14, 2007
Anonymous
  • 541 Answers
SOURCE: My Toshiba 27AF41 TV won't turn on when I press
This set is full of safety circuits that can cause this. It is really hard to say because anything can cause that. Have a shop check it out for you. Thanks for using fixya.
Posted on Jan 21, 2010
freetek
Steve Allison
  • 5569 Answers
SOURCE: what does blinking red light mean on power button
It may be a failure of the transistor that drives the flyback which would be much cheaper, easier, to source and replace. You really need at least a multimeter to check the transistor; checking the flyback requires a different instrument not commonly found at home. The precautions previously mentioned apply since the HV circuit may not be at fault meaning there could well be high voltage at the described terminal.
Posted on Feb 14, 2010
Tv not coming on has a blinking power button
Toshiba CX36F85 36" TV Blink - Questions - Fixya
www.fixya.com > ... > Toshiba > Toshiba CX36F85 36" TV
Toshiba CX36F85 36" TV, blink related issues. ... Every brand TV will have its ownblinking ... stand by light blinks 6 times, wont power on tv is only 4 years old. ...From the number of blinks occur at one time switch ON, you can get an idea ...
Toshiba CX36F85 36" TV Blinks - Questions - Fixya
Toshiba CX36F85 36" TV, blinks related issues. Get free help ... Every brand TV willhave its own blinking codes. From the ... Push power button and it ... and then ... stand by light blinks 6 times, wont power on tv is only 4 years old. Junk! it wont ...
Toshiba power light blinking not turn Standard (CRT ... - Fixya
www.fixya.com > ... > Standard (CRT) Televisions
Red power button blinking but tv won't power on
chec your ic register diode and transistor.
aslo check poer supply waltage and earthing properly.
My toshiba TP48E60 model projection tv won' turn on, power light just blinks
Blinking of power LED are fault indications. Count the number of blinks occur at one time switch on. For this number, you can get an idea about the faulty section circuit inside it. It will make troubleshooting much narrower. If you wish to get more details about the blinking codes, check this link. Pull up older posts there.
What does the blinking red light mean on a Toshiba TV model number 61A60A?
The set is in "shutdown" because of a short in the set.
Most common area in this model is the Convergence circuit.
8helpful
2answers
The power light blinks 3 times. What does this mean?
Toshiba Flat Panel Television how-to instructions, help and tips Three times so far, just the tv not the cable. Toshiba Flat Panel .... Timer light blinking red. TV will not turn on by power button on TV or using the ...
tv.manualsonline.com/.../toshiba/.../flat_panel.../product_problem toshiba.justanswer.com
2helpful
Theatre View Toshiba Rear Projection TV 50 Inch with no sound or picture and a red light keeps blinking
I have the sames t.v you have to go in the back flip the power cord switch...then reboot the t.v.
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
