Question about Dell Inspiron 14 Laptop Computer (Intel Pentium Dual Core T4500 320GB/3GB) (endoca13) PC Notebook
Dell inspiron n 4010 hangs often
My dell inspiron n4010 often hangs recently.. What may be the problem, Is it due to over heated or fan problem.....even if i use cooling pad, i face this..Some suggested that it may be due to wifi connection.. so they advice to go for LAN... kindly help...
Posted by Dinesh kumar R on
  • Dinesh kumar R May 18, 2012
    thanks for your tips in correcting my problem,, Actually my friend also had this same problem and it was solved by not connecting to wifi connection.. so once i tried to not connecting wifi and always works with LAN internet facilities,now am not facing this hanging problem for two days... i dont know the real problem why its hangs when i access to wifi.. so i thought that there s s/w problem so i reinstalled wifi.. again am getting same problem,,, so presently am not connecting to wifi ,.. please add your suggestions too...
joecoolvette
  • Dell Master
  • 5,660 Answers
I suggest you open the laptop, and clean it out first. THEN go on with the diagnoses.
Dell Support > Inspiron n4010 Notebook PC > Service Manual,
http://support.dell.com/support/edocs/systems/insN4010/en/sm/index.htm
1) FIRST remove all power. Remove the AC adapter (Charger) and Battery.
2) FOLLOW Anti-Static Precautions.
Anti-Static Precautions:
Your body carries Static electricity. Static WILL fry out (Short Circuit), the delicate hardware components on a computer.
Relieve your body of Static.
You should use an ESD wrist strap, and connect it's alligator clip to a good ground source.
This is an example of an ESD wrist strap,
http://www.radioshack.com/product/index.jsp?productId=2103245
This pictorial guide for disassembly of an Inspiron n5010, should help also.
http://www.insidemylaptop.com/taking-apart-dell-inspiron-n5010-inspiron-15r-laptop/comment-page-1/#comments
The screws, and cables, etc., are in a different place, but disassembly is still the same.
Use a can, or two, of compressed air for computers.
Also you may wish to use Q-tips, and a soft small brush.
(Makeup brush? )
DO NOT use a vacuum!!!!
A vacuum creates Static electricity.
For additional questions please post in a Comment.
Regards,
joecoolvette
Posted on May 16, 2012
  • joecoolvette
    joecoolvette May 19, 2012
    Tried downloading, and INSTALLING the WI-Fi driver? (Many download, but fail to realize it has to be INSTALLED also)
    Yes?
    Then suggest the Wi-FI module in the laptop is bad, or possibly has loose connections.
    1)http://support.dell.com/support/edocs/sy...
    2)http://support.dell.com/support/edocs/sy...
    3)http://www.ehow.com/about_5556826_blueto...
    Remember, ALL power removed before starting. Remove the AC adapter, (Charger), and Battery.
Gaurav Kumar
  • Dell Expert
  • 560 Answers
First check that cooling fan of dell laptop is working properly or something is wrong. If you get anything wrong, then first clean the fan & check again. If it is still not working so you need to replace your cooling fan with new one.
If your hard drive faces any issue, so you need to fix it before replacement of laptop cooling fan. You can also run complete disk scan program to check & fix the errors & bad sector. Also defragment your hard disk so that every necessary file can be easily access at booting time.
So these are very solution if your dell laptop is facing hang/freeze problem.
Feel free to get solution for your Dell Inspiron computer with Dell technician at http://www.vtechsquad.com/dell-support/
Posted on Sep 04, 2012
4 Related Answers
brismac
  • 93 Answers
SOURCE: we need not able to connect internet due to lan
reinstall the driver from the supplied discs. You put the disc in the drive and then let the computer boot. OR see here for new drivers
http://search.dell.com/results.aspx?spf=Inspiron&ssysid=inspiron_N5010&ssysn=N5010&s=biz&c=us&l=en&cs=555&ec=&ira=False&cat=sup&subcat=dyd&rf=all&evl=&nk=f&k=Inspiron+N5010&p=1&nf=&rpp=12&sort=K&~srd=False&ipsys=False&advsrch=False&p=1
Posted on Jul 06, 2010
Anonymous
  • 88 Answers
SOURCE: my Dell Insipiron N4010 intel
These fan are meant to run constantly at a low power and on high when using a lot of processing power (like playing a game or HD movie).
I would boot into Dell diagnostic and make sure the high and low settings of the fan aqre working properly it may be that the fan is on high all the time when it should be in low mode.
Dell Diag. Press F12 at boot Select Dell Diagnostics Go through the basic diagnostic ~5 minutes After basic diag the advanced diagnostic will start Go through the menu and select the Fan test
Posted on Mar 15, 2011
Jose Quiñones Jr.
  • 132 Answers
SOURCE: i bought dell inspiron n4010
1. Try going to this website
http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=19&l=en&s=dhs&ServiceTag=&SystemID=INSPIRON_N4010&os=W764&osl=en&catid=&impid=
2. The default OS is Windows 7 and Click on the Network Category
3. Click on any any wireless driver available
Thanks for choosing Fixya
Posted on Jun 10, 2011
SOURCE: dell inpiron n4010 bios
Go to google and type in "dell support" (without the quotes) in the search box. Look for drivers and downloads and click the link. Input your computer's model (inspiron n4010) and the operating system. You'll see all the drivers including the ones that pertain to flashing the bios. Download and install it.
Posted on Mar 21, 2012
Fusible dell n4010 ubicacion
Remueve la bateria y trata utilizando otro Power Supply. Si aun asi no enciende verifica que no este roto el conector de poder que est? en la laptop. Si est? roto es posible que si tenga un corto y requiera una labor m?s extensa y profesional.
Aug 15, 2014 | Dell Inspiron N4010 Notebook
Dell inspiron n4010 2 beeps problem
does it still start up after the beeps?
if not check your ram.
May 26, 2014 | Dell Inspiron Computers & Internet
Hello..my laptop is dell inspiron n4010..well the problem with my laptop is that the fan doesn't work when the laptop is on..and due to excess overheating the laptop becomes extremely slow.the wor
buy a coolpad .its cheap and have 2 or 3 fans in it some have even 4 fans
and it is very easy to attach with laptop through usb port just like a pendrive.
buy it . coolpad will prevent ur laptop from over heating.
Nov 16, 2012 | Dell Inspiron N4010 Core I3 2.53 Ghz...
I cant open my dell inspiron N4010. always hangs p when opening... how to restore it.. even pressing the boot options and enter set up still keep on hanging.. what to do please..??thnx
this is software problem i.e windows try to reinstall your windows and format all the partition this is usually occours by viruses . it takes hours at startup and at launching any app.
for backup your files reboot your computer and press f8 key and run computer in safe mode copy all the important files on your flash drive
Aug 11, 2012 | Dell Inspiron N4010 Notebook
Hello, My Dell inspiron Laptop is getting overheated. I think the fan is not switching ON. Laptop just switched off while working. Help!
Could you normally hear the fan but cannot hear the fan now? If so that is definitely a hardware issue and you will need to send it into Dell or take it in to a PC repair place.
Other than that, make sure you are setting your computer on a flat hard surface, like a desk obviously. If you were to for example set your laptop on the couch and use it, the couch makes the laptop heat up a lot faster.
Thanks for using FixYa.
Aug 20, 2011 | Dell Inspiron N4010 Notebook
I have a dell inspiron N-4010 14" laptop. I have played some .flv format songs in my VLC player yesterday iwth maximum Computer & VLC Application volume. After some time the speaker started...
Hello
Check your system with external speakers, if it gives same problem its mean that the audio drivers od the system gone corrupt, needs re-installation,
if the system gives the correct sound, means that the speakers gone damaged, need repair/replacement, you can do by your self if you are technical enough otherwise you need technical assistance from Dell Support
Good Luck
Feb 17, 2011 | Dell Inspiron 13R (N3010), 14R (N4010),...
Dell Inspiron 14 Laptop Computer (Intel Pentium Dual Core T4500 320GB/3GB) (endoca13) PC Notebook Logo
804 people viewed this question
Lee Hodgson
Lee Hodgson
efs_perpends
efs_perpends
Michael Thomas
Michael Thomas
