Service call fatal error 172
SOURCE: 980: Fatal Error
From the Service Manual:
*Service call
980:Error
*Error by media
clinging to the fuser
*Media has clung to the fuser.
*Power OFF
Replace the fuser unit.
Suggestion -
Before you replace the fuser, take it out and check for a piece of stuck label, paper, etc. You can spin the fuser roller by turning the gear on the side.
Posted on Apr 07, 2008
SOURCE: OKI C5500 Fatal Error 177
From OKI error log:
Lower heater temp state - Low
backup roller thermistor indicates low temp
seek service if turning off/on printer does not solve problem
Posted on Dec 08, 2008
SOURCE: OKI C5900
Most likely you have paper wrapped around the fuser or at least stuck in the fusers sensor So remove anywhere you can see paper. If not it will need a replacement fusing unit.
Posted on May 01, 2009
SOURCE: How do i solve fatal error 980
Hi
Thanks for using FixYa. Error 980 on OKI C5600 means that
the error by media clinging to the fuser and the fuser is required to be
replaced.
Please do rate the solution and revert for further
assistance.
Thanks
Rylee
Posted on Sep 14, 2009
SOURCE: fatal error 980 OKI C5500 printer
I had a paper jam and removed the jammed papers. The paper jam cleared and then the Fatal Error 980 appeared. OKI C5500 printer
Posted on Feb 25, 2010
Aug 29, 2014 | Oki Electric Industry C330dn Led Card...
Dec 31, 2010 | OKI Electric Industry B4545 Laser Printer
Aug 26, 2009 | Office Equipment & Supplies
Jun 23, 2009 | OKI C5200n Laser Printer
Jan 27, 2009 | OKI C5100n Laser Printer
Apr 15, 2008 | OKI C5500n Printer
Apr 07, 2008 | OKI C5800Ldn Led Printer
Aug 10, 2007 | OKI C5150n Led Printer
Jun 02, 2006 | OKI C9300 Led Printer
179 people viewed this question
