Televison & Video Logo
Jaime Morell Posted on May 15, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Video and audio issue on my Sanyo DS31590 T.V.
This T.V. has a horizontal line in the middle of the screen and no sound.
Anonymous
Level 3:
Top Expert:
  • Master 14,553 Answers
  • Posted on May 15, 2012
Anonymous
Master
Level 3:
Top Expert:
Answers
14553
Questions
Helped
2738296
Points
48227
Line left to right is vertical circuit problem and may be linked to audio problem if both are fed voltage from a common source---Not a do it yourself repair unless have experience with this kind of equipment.
5 Related Answers
Anonymous
  • 45 Answers
  • Posted on Nov 25, 2007
SOURCE: Nopicture
No vertical deflection. Vertical output IC, caps.
salt56
TV Doctor Repair Consult
  • 373 Answers
  • Posted on Dec 30, 2007
SOURCE: Sanyo DS31590 31" TV vertical deflection
If the vertical is not defective or shorted there is a possiblity of bad solder connections on the vertical ic. If connections are good and has b+ voltage to the chip replace chip which is IC 501 LA7841 or LA7845 and change c511 (decimal point 1 film capacitor)
Anonymous
  • 230 Answers
  • Posted on Jul 24, 2008
SOURCE: Thin Horizontal line through tv blank screen.
Replaced vertical IC ( la78041 ??>.. Or La78040 ). Look for born resistor beside IC. Replaced capacitor 100uf 35V too!!! Good luck !!
The witch
Francisco Mauricio G
  • 1551 Answers
  • Posted on Oct 08, 2008
SOURCE: Sanyo C25EG95 Thin Horizontal line in the centre of screen
Vertical IC output burned out
Anonymous
  • 105 Answers
  • Posted on Jul 01, 2009
SOURCE: my sanyo ds31590 31 has a black picture with a thin white line in
check the voltage at vertical ic must get 24volt dc then replace the IC that all
Tv has horizontal line in middle of screen,sanyo ds25390
hi if only a horizontal line across with no video anymore, you have bad either vertical ic or no dc supply b+( vertical ic ) or no output dc coming from the ic. if it is not totally a horizontal white line and you can see a video you must check leak or bulged capacitors at the vertical section near the vertical ic. hope this can help good luck.
1helpful
I HAVE A SANYO MODEL 31590 NO PICTURE SOUND JUST A LINE IN THE CENTER
hi..hope this help you....a horizontal line in the center is an indication of defective vertical IC...its looks like a tab w/ 10-12 pins and has heatsink...your TV would works out fine when you replace the IC....but its better if let a technician replace this....pls. don't forget to rate and vote....thanks...
2answers
My SANYO TV24'' when powered on,only a bright horizontal light appeared after 3sec dissapered,no sound,no more picture.
your tv has suffered horizontal collapse this is not a cheap repair it contains most major parts of the power section
hope this helps
My sanyo ds31590 31 has a black picture with a thin white line in
1helpful
2answers
TV has a thin horizontal line across the screen
intermintence in vertical IC deflection its a job for experienced tech need to look for that circuit and do fine job resolding that IC
Vertical Deflection
check soldier connections on vertical i.c.
1helpful
Line on t.v. no picture
If you are getting a horizontal line across the screen, It means the vertical amplifier IC is defective.
1helpful
1helpful
Tv not working
this symptom, sometimes called the tube light effect, it is characterised by a bright thin horizontal line across the middle of the screen. this symptom is caused by a breakdown in the vertical deflection circuit. hence maybe the trouble maybe in the vertical oscillator, amplifier or output circuits. but if all i have said is not clear to you, better bring it to a qualified tv technician. good luck!
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
