SOURCE: Older Polaris doesn't sweep
pantera ll by wicor sand filter distributes the sand back into the pool, what could the problem be?
SOURCE: polaris 380
polaris has belts in side it if your handy you can replace them your self if not any pool place can do it but it is a belt i have a 380
SOURCE: polaris 180 pool cleaner is running slow and not
Hate to say it but they don't make them anymore. Spend the money and buy a Polaris 280
SOURCE: Back-up valve is not working properly. Can I take
With these pool cleaners, if they are not backing up, there are several things that you could try. Lift the valve out of the water and watch the jet. It should be going on and off. If it is not, you will need to replace the back up valve. If it appears to be working properly, try adjusting your wheel RPM.
SOURCE: My Polaris 3900 Sport Pool
If your pool cleaners not making proper cleaning patterns on the pool floor or turning it tight circles, try checking your RPM and adjusting your thrust jets. If the RPM is higher than 32, you will need to decrease the water flow. Also, make sure that your feed hose is floating and is not becoming tangled. Finally, check the filter bag, if full it can weigh the cleaner down on one side.
