Cars & Trucks Logo
ralf boehner Posted on Jan 10, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Code p0170 error code 0170 comes up, starts rough for about five seconds then purrs perfectly, runs fine up to half throttle any more and the 02 sensors shut down and she losses power. changed fuel filter,spark plugs, leads,o2 sensors, checked fuel presure, change fuel injectors,checked for air leaks in manifold.
Edward Cole
Level 2:
New Friend:
Greenhorn:
A rookie expert who has answered 20 questions on their first day.
  • Expert 42 Answers
  • Posted on Jan 10, 2018
Edward Cole
Expert
Level 2:
New Friend:
Greenhorn:
Answers
42
Questions
0
Helped
11417
Points
103
Possible intake manifold air leak. Try spaying water around intake gasket and see if rpm changes. Faulty front O2 sensor, faulty MAF
Jeff Armer
Level 3:
  • Chrysler Master 15,575 Answers
Jeff Armer
Chrysler Master
Level 3:
Answers
15575
Questions
Helped
7111273
Points
73899
What year vehicle ? mass air flow or speed density fuel control . Do you have a scan tool that can view sensor data . What are the fuel trims ( short & long term ) showing ? PCM problem ? O2 sensors stuck lean , adding propane , do the O2 sensors go rich ?
5 Related Answers
Anonymous
  • 16 Answers
  • Posted on Feb 22, 2009
SOURCE: 91 honda civic dx 1.5L quit running properly.
bro, check ur main relay. its under the dash. replace it, check also ur distributor(replace it). and also your ECU
Testimonial: "right answer but I received it much too late. I went to a mechanic and paid him to fix it."
Oliver Street
  • 73 Answers
  • Posted on Mar 21, 2009
SOURCE: 91 LEGACY STARTED RUNNING ROUGH
The cylinders are numbered as on the spark pack you changed. You might have done better putting the seafoam in the tank as an injector cleaner. Not sure why you changed so many parts, you seem to know how to get the codes from test connector lead hookup and the blink pattern. You might also want to check the fuel rail pressure and the crank and cam angle sensors. Before replacing the injector, swap the #4 injector with the adjacent one and see it the code moves with the injector or stays put. If the code stays on #4, then check the injector wiring, if it moves clean or replace the injector.
jamieallen29
  • 51 Answers
  • Posted on Aug 15, 2009
SOURCE: Chevy truck '02 surges between 45 and 55 mph
you should change the tps( throtal position sensor) this can cause that problem
Anonymous
  • 25 Answers
  • Posted on Oct 21, 2009
SOURCE: I own a 2002 Chevy Trailblazer with 4200 vortec
Do you know if the plugs were changed, a bad or broken plug will also cause rough idle and slow acceleration?
Randy Ohler
  • 14585 Answers
  • Posted on Dec 02, 2010
SOURCE: I have a 2003 Expedition
Most likely the coils. Easiest way to check is swap them with another cylinder, start it, pull the plug wire connecter and if it doesn't change the engine the coil is bad. If it is the injector, then you can check it with an ohm meter. Touch the leads in the injector it should read 11 to 15 ohms. if you need help let me know.
Randy
2005 Dodge Town & Country will start but will not stay running when it's cold. After car warms up or in high temperatures it runs perfect
Clean the Throttle Body and MAF with Cleaner. That causes rough idle.
Also drop a bottle of Fuel System Restorer into half a tank of gas.
More ideas here, but start with the above.
https://www.google.com/search?q=2005+chrysler+town+and+country+rough+idle
2010 Ford F150 would suddenly loose power and only idle. Pull over shut off sit a couple minutes crank and run fine for a while then do same thing again. Wrench would show up on instrument panel
Sounds like the catalytic converter or muffler maybe getting plugged up and the computer is putting the truck in limp home mode. Did you put a scanner on the truck. You might try to remove the 02 sensor ahead of the cat and see if it runs a little better it will not be perfect but should stay running if so do an exhaust check. When the cat or muffler gets plugged it puts back pressure on the engine and won't allow the fuel to be pulled into the engine properly.
Dash symbol car with spanner through
Your car only has one bank, so this code applies for the entire engine. I'll provide a link that gives a good breakdown of what P0170 means, possible causes, and possible corrections.
P0170 Fuel Trim Malfunction Bank 1
P0170 runs rough
code p0170 refers to fuel trim (FT) bank 1--malfunction===causes--intake leak---AIR system fuel pressure/pump/injectors--EVAP canister purge valve--HO2s
It also refers to heated oxygen sensor (HO2S) 3 bank 1--circuit malfunction===causes --wiring---HO2S--ECM
fix the o2 sensor and the purge valve and you may be on the way to fixing the faults.
1996 dodge caravan 2.4 code p1294
on dodge motors
fitted a lot of parts and still no better
the fault code clears and comes back as a intermittent problem
could be electrical voltage drop off or heat related failure
i wonder if your 02 sensor ,the catalytic converter
or other related sensors
are causing the fault to come back
if needed .....fit a new air filter...
how the test is determined
P1294-TARGET IDLE NOT REACHED 3.3L/3.8L
When Monitored and Set Condition:
When Monitored: With the engine idling and the transmission in drive, if automatic.
There must not be a MAP sensor trouble code or a Throttle Position Sensor trouble code.
Set Condition: The engine idle is not within 200 rpm above or 100 rpm below the target
idle for 40 seconds. One trip fault.
POSSIBLE CAUSES
INTERMITTENT CONDITION
IAC MOTOR PASSAGES
VACUUM LEAKS
AIR INDUCTION SYSTEM
THROTTLE BODY AND THROTTLE LINKAGE
TEST ACTION APPLICABILITY
I have a 2005 Ford Five Hundred Limited AWD. I have a problem starting the car. It may crank for 5 seconds before half-starting...it will idle rough at ~500 RPMs for a couple of seconds and may stall, or...
Burn the lowest octane that you can, based on the specs. Ford has found when people run premium fuel, starting was delayed.
It is actually the lowest octane that has the most explosive power. Higher octane burns SLOWER.
2helpful
1998 mazda mpv code p0170 erase code car runs fine but when i stop for a few minutes it is hard to start and runs rough the engine light comes back on and the code will read p0170 again
This code indicates a fuel ratio problem. I would start by inspecting all the vacuum lines, including the pcv hose and power brake hose. Carefully inspect the air intake hose. This is the large hose between the throttle body and the airflow meter. If this hose is cracked or loose the computer will not sense how much air is being drawn into the engine and it will be hard to start.
2006 RAM 1500- COLD STARTING POPPING FROM INTAKE, AFTER WARM OK
sounds like u might have a sticking valve. i do know that they have had alot of valve problems with this motor
Top Chrysler Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Chrysler Expert? Answer questions, earn points and help others
