Question about Gaggia Baby Coffee Makers & Espresso Machines
Low flow, pump starts normal and within a few second becomes quiete
Hi, my Gaggia Baby Classic doesn't generate the same level of water flow it used, when i press the button to make a coffee, the pump starts loud as it should and then within a few seconds it drops to a muffled sound. the water coming through the head is no more than a trickle, so making a good coffee is out of the question. The steamer seems to be working fine. i have dismantled and cleaned the head. what next? Thanks.
    Habit-Forming:
    New Friend:
  • Gaggia Expert
  • 64 Answers
Hi There,
Try descaling - sounds like the the solenoid is blocked with lime - don't use vinegar! Try that 1st.
If machine is more that 2 years - not regularly descaled or no water filter replaced regularly, it probably the solenoid.
It the machines is 4 years + replacing both would be a good idea. Gaggia classic solenoid Vibration pump Gaggia Rancillio
Posted on Oct 25, 2017
5 Suggested Answers
Anonymous
SOURCE: PROBLEM WITH LOW FLOW/PRESSURE IN GAGGIA COFFEE DELUX COFFEE MAKER
the most likely reason for poor flow through the brewhead is a blockage in the outlet valve.the outlet valve is behind the shower disc holding plate and can be removed with 13mm socket. a straightened paper clip needs to be insrted in the outlet to clear any internal blockage,then pump water through. if the outlet valve splits in two ensure the rubber bung is inserted upwards.once refitted all should be fine
Posted on Aug 07, 2008
Anonymous
SOURCE: gaggia baby dose d (circa 2007) wont dispense water? pump?
Sounds like it needs descaling - not the normal descaling but inside the pump head!
Posted on Oct 30, 2008
EsWorld
Ernest R
  • 1618 Answers
SOURCE: Gaggia evolution not producing coffee
One question before I make any suggestions: If you remove the shower screen and screw, do you get a nice flow of water or is it still steam?
If you get a nice flow of water, then check your screen hold it up to the light and you should be able to see through the tiny holes, if not, get a pair of needle nose pliers and being very careful hold screen over an open flame like the stove burner. The coffee will burn before the anything happens to the metal. When it is cooled screw into group and see if the flow of water is better.
If you get nothing but steam then it is time to descale the machine.
Posted on Apr 06, 2009
royoh
  • 5 Answers
SOURCE: GAGGIA BABY. NO WATER COMING OUT.STEAMER FINE
I had exact same problemeven took entire machine apart - all fine. Solution is very simple... descale with Gaggi descaler solution. Remove filter and block, mix solution with 1.5L of water, turn on for 20 seconds, wait 20 rinse through steamer, wait 3 minutes and repeat until all solution used - rinse compeletly with clean water
Posted on Apr 25, 2009
Anonymous
SOURCE: Gaggia Classic Espresso Machine - will not pump water
Hi, this is so easy to fix. Firtsly unplug the machine. Then remove the two screws in the top plate so that you can have access to the internals of the machine. You will see the red pump to the left hand side at the back. Remove the two screws that hold the pump in place (use a magnetic screwdriver so that you can pull the screws out). Pull the pump up towards you and then unscrew the thin plastic pipe at the top of the pump . It is the pump that has the scale build up problem. If you the put the water tubes into the water tank and hold a cup to the top of the pump to catch the water you then have to switch the pump on. You will then start to see lots of scale come out of it and the pump will pump more water than you are expecting so be careful. Be sure to cover the internals of the machine whilst you are doing this as you don't want to get water on the electrics and electricute yourself!!! Then rebuild it! Just svaed yourself £100 in having it serviced :-)
Posted on Nov 01, 2009
No water flow, low motor sound, weak steam
looks like your shower disc is blocked remove screw under head you well most proberly find it is blocked when looking up to light clean disc with brush until you can see through holes reassemble you will find flow and steam are better hope this helps
Dec 13, 2012 | Gaggia Baby Espresso Machine
Low pressure
Sounds like it is starving for "water". Check that you have sufficient pressure and flow to the inlet. Doesn't take much pressure, but flow has to be more than pump can put out.
Sep 28, 2012 | General Pump TT9061EBFU - TT Series 51 -...
Intake valve make a vibrating noise after a few minutes
From what you are explaining it sounds like the pump is taking on air, which I have seen when the water level is just a tad low & the pump creates a "vortex" at the skimmer box & air is sucked in. Double check the "flap" at the skimmer to make sure it is working properly (not stuck upright)
Jul 13, 2010 | Intex Krystal Clear Model 635 Pool Filter...
1975, 7.5 Kohler marine genset, runs only with the reset depresed
Can't search for a manual without model, type, serial, etc numbers...
A few things to take a look at:
1) Oil level / pressure sending unit. This is normally bypassed as long as the start switch is pressed. When engine starts, and switch is released, engine will die if sending unit is defective, or you are low on oil.
2) Exhaust temperature sensors. Older units were notorious for burning these up.
3) Cooling Water Temperature sensor. These cause trouble often, but mostly due to water pump impeller being eaten away by galvanic action and not able to pump water as effecively. End result is water temp higher than normal, which trips the switch, which kills the engine.
4) Alternator (generator) output not as it should. If output doesn't rise to proper level within a few seconds of engine start, the engine will be shut down.
5) Choke not working as it should
6) Bad fuel, bad fuel pump, clogged fuel filter.
May 26, 2010 | Kohler Electrical Supplies
My baby gaggia dose (brand new out of the box) leaks
HI
Call who ever you bought it from and have them diagnose the problem. I think you have a disconnected hose or something worse.
Nov 18, 2009 | Gaggia Baby Espresso Machine
The pump isn't pumping. The machine is making the
Hi
There are no diaphrams in high pressure pumps. They use a small piston and check valves that can become stuck. Some can be fixed but that old it might be better to get a new pump. You can sometimes find them on ebay.
Oct 14, 2009 | Gaggia Baby Espresso Machine
No water coming through - New Gaggia Baby Dose
Try this remove the portafilter, then press the button for brewing coffee and then turn on the machine, if both hoses are in the water reservoir, then water should flow out of the head after a few seconds.
Jul 20, 2009 | Gaggia Baby Espresso Machine
Gaggia baby dose d (circa 2007) wont dispense water? pump?
Oct 25, 2008 | Gaggia Baby Espresso Machine
Low water flow from gaggia evolution only 6 months old, have tried descaling, no obvious scale found in machine. pump starts but goes quiet, very feeble flow of water.
I have now solved this problem. The lack of flow associated with the pump working but running quietly is caused by the Group Head being blocked with limescale. Normal descaling cannot remove it because it cannot penetrate the Group Head.
Removing the Group Bell can be achieved using a collection of screws (see photo) and works no matter how stubborn the thing: levering it with a screwdriver in my case was impossible as it was so well glued on. 6d47425.jpg
I figure that the advice to replace the rubber seal once per year is a good one because it forces you to remove the Group Bell and clean it out.
Apr 29, 2008 | Gaggia Baby Espresso Machine
Coffee Makers & Espresso Machines Logo
130 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Pierre Laplante
Ekse
Marvin
Marvin
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
