Windows 7 service pack 1 when downloading it says 0KB 0% downloaded I recently used my recovery discs to reinstall as WIN32 had some corrupt files. This is the very last update
Run the chkdsk utilty
click start type cmd press enter you should see a black screen dos mode
type in chkdsk/f/r press enter this will schedule to occur on restart
have no input while the chkdsk utility is in progress any input might further damage your computer and its operating system
then try the update again
hope it helps
SOURCE: missing or corrupt windows\system32\config\system file in XP
sciberteach:
Go in the BIOS, in the boot sequence make your DVD player as the 1st number device to boot from, restart your machine and do follow the article (you should know the admin password to go into the system drive):
http://support.microsoft.com/kb/307545
Note: If you are too overwhelmed then your Product recovery DVD will give you your original OS and all settings back.
SOURCE: I am in need to install recovery console
Here's How:
Boot From the Windows XP CD
To enter Recovery Console in Windows XP, you will need to boot from the Windows XP CD.
Press R to Enter Recovery Console
When the Windows XP Professional/Home Setup screen appears, press R to enter Recovery Console.
Choose the Windows Installation
The Recovery Console
is now loading but needs to know which Windows installation to access.
Most users only have a single Windows XP installation so the choice is
usually clear.
To the Which Windows installation would you like to log onto question, press 1 and then Enter.
Enter the Administrator Password
now needs to know the administrator password for this Windows XP
installation. Unless you are using a PC in a sizable business network,
the administrator password is most likely the same password you use to
access Windows XP on a daily basis.
To the Type the Administrator password request, enter the password and press Enter.
Note: If you do not have a password or Windows XP normally starts without asking for one, simply press Enter.
Make Necessary Changes in Windows XP Recovery Console
The Recovery Console is now fully loaded and the cursor should be sitting at the command prompt, ready for input, as shown in the screen shot above.
Make any changes necessary in the Windows XP Recovery Console. When complete, take out the Windows XP CD and type exit to restart the computer.
bootcfg /rebuild
Type Y in response to this question and press Enter.
This is the name of the operating system. For example, type Windows XP Professional or Windows XP Home Edition and press Enter.
Type /Fastdetect here and press Enter.
Assuming that a missing or corrupt boot.ini file was your only issue, Windows XP should now start normally.
Show your appreciation by rating it.
SOURCE: Installing windows XP - Error encountered
Can you reboot and get into windows or is now corrupt?
What do you mean by 'uninstalled XP'??
You cant uninstall it unless you format the drive, in which case the recovery discs are now probably useless as they rely on a folder on the HDD called i386.
Recovery discs normally dont have the OS on them, they rely on the I386 folder to gather info about the computer and then restores it to the state when it was new.
If you can acess the system, reboot and go into the bios and change the boot sequence to CD, then insert the first recovery disc. then save the settings and the computer will reboot and start the recovery process again, this should clear up the error.
If it does not it will be because the i386 folder is missing in which case you can either explore the recovery discs for it or you will have to buy a copy of Windows XP.
SOURCE: recovery disc problem
Yes, you will need a fresh copy of a OS/boot your machine with cd in tray and follow instructions/then place recov cd in tray/go to my computer and right click/cd and explore/look for drivers and install alon with any onther software you need
SOURCE: reinstalled windows xp on tecra a2, need all drivers
Two things to try, install service pack 3 for xp, and go to the Toshiba website look up your laptop and see if they fave drivers that are compatible with xp sp2 or sp3. Hope you find what you looking for and this info helps. GL
Note that this download is no longer free
hope this helps
