I put bike together ran perfect he changed the plastics unpluged some wire harnesses after putting everything back together the bike wont start just hesitates he bent the kickstand out alittle more i figured maybe the stand sensor but bike would still start
SOURCE: 97' cbr 600 rr f3 doesn't start
check to see if fuel switch is on...when was the last time carbs were checked?
SOURCE: honda cbr 600 rr 2005 fuel tank removal
I had an 07, I had to remove the lower and side fairings and then the bolts are visible, dont just lift it up because wires and the fuel line will be connected and tight. When you lift it, lift easily so you dont just rip everything, you should be able to lift it high enough to disconect the wires without damage.
SOURCE: 1998 Honda Goldwing will not start nothing.
Sort of sounds like a Twilight Zone kind of problem doesn't it. I would have the battery checked for an internal dead short. This is something that happens on odd occasions and can happen even to a new battery. Yea, the little lights will work ( they do not draw much juice ), but the starter motor draws a lot of juice and a shorted battery just ain't got it. Also check the wiring harness connections. One loose connection can cause bunches of trouble.
SOURCE: i need wiring schematic
I bought a cbr 600 , but bike came with the wirers not connected. Rectafire, was also not connected? need diagram or help really badly!!!!
SOURCE: I own a honda steed 600 v twin. the side stand
Dont know what the filter got to do with it, but side stand switches are normally closed when retracted, simply wiring the two ends together will give continuity till you get around to repairing the wires which are located on the stand pivot arm, lay bike over and look under, likelihood is wires are damaged around swinging arm area, so you must connect wires prior to break and insulate. PS, disconect battery first.
