SOURCE: My dishwasher runs for bour 10 minutes. Then stops, and flashes PF?
Mine does the same thing. I'm confident that the problem lies in the "computer" which is essentially the buttons for selecting the various wash cycles. That strip is basically a thick band with adhesive on the back by which it is glued to the top of the dishwasher door. There are wires connected to it. The wires run down into the door and connect to a terminal that is built into the door. The inside door panel must be removed to install a new button strip or "computer." Mine was replaced twice in the first year. Now it is three years old and needs to be replaced again. I'm going to look around on the net to see if I can find one.
Davey
SOURCE: just installed the dishwasher and
Hi, I am doing some Research at this moment. Will get back to you,
Shastalaker7
Hello Colton Rawlings, thank you for your post!
Based off what you are describing "PF" stands for power failure on a Frigidaire dishwasher. If the lights are dimming then your appliance flashes "PF" it could possibly be an issue within your panel or your appliance is not getting enough power to it. I would recommend contacting a professional to come and diagnose your appliance properly. I hope this is helpful. -Matt
Here is a tips that I wrote
that will help to explain why you get the PF Error Code
PF
Error Code for Appliances
heatman101
PF
heatman101
PF
heatman101
PF
heatman101
,./;''l
PF is a generic power failure code. You might have experienced a power surge in the house. Please reset the unit at the household circuit breaker and go from there.
