How do I Fix LCD White Screen?
Turn monitor on all i see is fractured lines going across the screen for a few seconds then the screen goes completely white and stays white forever..most of the time the monitor doesn't even turn on
Posted by saiyanbob666 on
Art Ellison
  • 2,229 Answers
If you see "fractured lines" across the screen, it would appear that your LCD screen is broken. That's the only way these kinds of lines appear.
You need to replace the screen.
Posted on May 15, 2012
5 Related Answers
Anonymous
  • 198 Answers
SOURCE: MAG L765b Model 780
Sounds like an inverter problem. If the power supply is internal replace the capacitors coming out of the voltage regulators. These are usually 1000mf and/or 470mf. If that doesn't do the trick look up the numbers on the 8-pin chips that drive the secondary transformers on the inverter to see if they are getting the right voltages.
Good Luck!
Posted on Feb 20, 2008
Craig McCarty
  • 55 Answers
SOURCE: my dell e196fp lcd monitor has white lines
Dell had a problem with horizontal lines in some of their monitors a little while back. I would try contacting Dell Tech Support to see if your monitor is one of the one effected. I think they were replacing the monitors that had the problem, but I'm not completely sure.
Posted on Mar 16, 2009
Anonymous
SOURCE: White horizontal lines flicker and screen goes off.
check the wiring inside the monitor, pull the sceen out and move the wires with the screen on so you can see when it's working. then tape the wires where it works.
Posted on Jan 31, 2010
SOURCE: Black & White lines across my monitor
1.Make sure all the connections are secure.
2.Try attaching the monitor to a different PC if possible, to determine if its the monitor or video card.
3.Your monitor might just be going bad
Posted on Jan 04, 2009
Anonymous
  • 188 Answers
SOURCE: Screen turns white only
http://www.daniweb.com/forums/thread17104.html
check out his forum thread. I think there is good information posted. I hope it helps.
Posted on Sep 20, 2008
White line across screen
If your LCD TV or monitor has stopped working, or is displaying one of the following
symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can
examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life
of your monitor or TV by several years.
Take it to a repair shop.
Apr 05, 2014 | Sony 46 KDL46EX523 LCD TV
Monitor flickers with lines across screen
screen is going bad which is why its flickering and has the lines across the screen. Theres a board behind the lcd and when that doesn't process the voltage properly it can cause the screen to flicker. White lines across the screen means the screen is going bad. At this point unless your monitor is under warranty, go ahead and replace it.
May 28, 2011 | Norcent Technologies LM-965WA Monitor
MONITOR HD2200. I TURN IT ON AND THE SCREEN GOES WHITE THEN A FEW VERTICAL COLOR LINES APPEARS AND AFTER A FEW SECONDS IT GOES BLACK.
IF YOU HAVE A SOLID BLACK LINE RUNNING VERTICALLY THEN YOU HAVE A FAULTY MATRIX INVERTER. IF CENTRAL THE MAIN VERTICAL INVERTER NEEDS CHANGED. LEFT = LEFT VERTICAL INVERTER RIGHT=RIGHT.........
ANOTHER WAY TO GET THIS FAULT IS WORN OR DAMAGED RIBBON/PLASTIC GOING FROM THE SCREEN MATRIX TO THE INVERTER
Hope this will help out in solving the problem....
May 21, 2011 | Gateway HD2200 LCD Monitor
Dec 16, 2009 | Proview PL926WBi 19" LCD Monitor
Screen goes blank after a few seconds
Hi ,
The monitor flicker problem. The monitor when turn on will display image for couple of second then turn black. The monitor status led is still green. This will happen each time it is turn on. The symptom at appear to come from the inverter board.
May 08, 2009 | NEC-Mitsubishi NEC Display Solutions...
A white line across my screen
It could be one of three things, the first two could be an easy fix, the last one calls for a qualified repair person and could cost you
-first, The lcd cable assembly is loose, make sure it's seated properly. if problem still exists try to Disconnect the monitor cable from the computer and turn the monitor on leave it plugged in to the electric socket.it will display a diagnostic colorbar are the lines still there. if not your problem might be a cable or video card. if they are still there have a technician evaluate the monitor.
-second, The inverter card may need to be reseated
-last, The lcd has a thin line crack and needs to get replaced
It would be helpful to know about the inner workings of an lcd screen and how to access them. It shouldn't be to difficult if your computer savvy. I want to caution you about getting shocked. an lcd still has power stored in capacitors. you should be able to drain those capacitors by leaving the monitor on and unplugging it from the electrical plug wait 10 sec or until all lights go out on the monitor.
If none of this works then Your monitor is defective, and nothing you can do to fix it... Call where you got it from for a replacement
Jul 11, 2008 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Solid line completly across screen, monitor is brand new
Your comp's video card refresh rate (in Hertz, abbreviated Hz) may not be totally compatible with the monitor. Check the properties of your video card, and change the refresh rate (you may have to look around for it) to 60 Hz. This is a pretty standard refresh rate that works with just about every monitor. If it's already there, I'm afraid someone else will have to try and help!
Hope this helps, and please rate my answer, good OR bad.
Feb 04, 2008 | ViewSonic OptiQuest Monitor
The FPD1975w
Replacing the lcd screen more than likely. Problem in the PCB thats built onto the lcd itself.
They are rather inexpensive these days to replace. I would just buy a new one. Check warranties offered before buying, some manufacturers offer 3 years. ;)
Oct 24, 2007 | Gateway FPD1975W 19" LCD Monitor
White screen with thin black line
it is the problem with the lcd itself just call the customer care they will be replace it.
Sep 05, 2007 | Samsung 710V 17" LCD Monitor
Computers & Internet Logo
3,006 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
