Question about Lenovo IdeaPad Z560 Notebook
Lenovo Ideapad Z570: Battery indicator shows the Power is plugged in & charging. But the Battery charge percentage doesn't increase. How to fix this?
Posted by sujith_ampar on
  • Anonymous Mar 25, 2014
    cockwogger
General Systems Consulting
    Top Expert:
  • 5,051 Answers
The battery might be nearing the end of it's useful life and needs to be replaced. The battery only lasts for so long then it has to be replaced.
Buy a battery on ebay base on your computer's Make and model, not the model of the battery.
Posted on May 15, 2012
5 Related Answers
Hollyecho
Hollyecho Montgomery
  • 318 Answers
SOURCE: Lenovo N100 does not switch to battery power
Batteries have a memory,
When the battery was new it most likely would run for 1.5 hours, but, since you didn't want the computer to go off, and you were by a plug-in, you plugged it in before it was completely or maybe sometimes not even halfway discharged. That is where it stated its "memory" - this got shorter and shorter = your battery "THINKS" it is totally discharged and reads as so.
There are programs on the web (can't advertize for pay programs or give you links to them - against the rules) - that will re-vitalize your battery to almost new condition by discharging it more and more till it is truly fully discharged, then will fill it back to like new charge time.
Or you can buy a new battery.
Posted on Jul 03, 2008
Anonymous
  • 54 Answers
SOURCE: I own a Lenovo ideapad intel atom processor. It
remove battery ,check weather your laptop is on or not on adapter only.If it is not then there might problem with your adapter.Need to replace adapter.
Posted on May 03, 2009
Anonymous
  • 38 Answers
SOURCE: Lenovo IdeaPad Y530 - 40512SU screen is dark
Have you installed the Lenovo EnergyCut drivers? Without it, laptop may not work properly and turns extra hot. Try letting it cool down before you try again.
Posted on Oct 28, 2009
Anonymous
  • 13 Answers
SOURCE: IdeaPad Y530-5243U 15.4" Laptop PC Notebook: My Lenovo ideapad Y530 fails to turn on with batte...
the battery of your ideapad is already defective, try to change battery
Posted on Jun 12, 2010
SOURCE: Lenovo Ideapad Y510 won't turn on or off
try removing the battery and removing the adaptor press and hold down the power button for 5-10 seconds then let got this will power drain your system board noy turn the system on using the battery only without any adaptors to charge or power the system, try turning the system on if the system turnes on leave it turned on for a couple of hours then conenct your sysem adaptor monitor if the battery light and the battery indicator on the lower right of the screen in windows woll indicate that the system is chargin if it is then I believe everything should be fine the blue indicator is for your system if it is blue then your system is turned on and has power if it turned orange and blnking then the battery will be more likely be almost out of juice or may need charging.
Posted on Jun 24, 2010
What can i do when my lenovo ideapad P500 wont charge
take it to a repair shop for battery replacement
May 03, 2014 | Lenovo IdeaPad Z570 Notebook
Lenovo z570 not powering on
Measure the voltage at the AC Adapter plug, and see if it is within 5-10% of the rated voltage. If the voltage is not correct, then the battery will most likely not be charging, and the system will drain the battery and die in the middle of what it was doing...booting in your case.
You can tell how much voltage is remaining in your battery and if it is charging by checking the blinking of the battery status light.
Download the Hardware Maintenance Manual here:
http://download.lenovo.com/UserFiles/UserGuide/en/User%27s%20guides%20and%20manuals/Z370&Z470&Z570/Lenovo%20Z370Z470Z570%20Hardware%20Maintenance%20Manual%20V1.0.pdf
and go to page 30 and look at item 7 under battery status for blinking light meaning.
1. Blinking amber: (500ms off/1s on)
The remaining power of the battery is less than 5% of
its capacity.
2. Blinking amber: (100ms off/3.2s on)
The battery is being charged with the remaining
power between 5% and 20% of its capacity.
3. Amber: The computer is operating on battery power with the
remaining power between 5% and 20% of its
capacity
With the AC Adapter plugged in, and giving the correct voltage, If you are getting 1. Blinking Amber (light on for 1 sec, off for 1/2 second), then the battery is not being charged. Could be AC Adapter, Battery or Battery Circuit on motherboard. If the light is solid on 3. Amber, then the battery is not charging, and is draining.
Also make sure the power socket on the laptop is not loose or damaged. If it is, then it will need to be replaced.
I hope this gets you in the right direction.
Apr 25, 2014 | Lenovo IdeaPad Z570 Notebook
Lenovo Ideapad z570 won't turn on Day before
Go on ebay & shop for a new PowerPak. That is your first step. If the battery is completely down from not charging is the exact symptoms you described.
I’m happy to help further over the phone at https://www.6ya.com/expert/wynn_5ba0205233ebfc15
Aug 31, 2013 | Lenovo IdeaPad Computers & Internet
Power cord light is yellow not green
Hello,Yellow means your battery charge is low, and it is being charged.
Green means you have a full battery charge.
So probably it seems your battery is out of juice. Keep it on charges & it should be fine.
If there is nothing changed, you may need to exchange the laptop charger.
Lenovo IdeaPad Z570 AC Adapter
Hope this helps.
Nov 01, 2012 | Lenovo IdeaPad Z570 Notebook
Lenovo Laptop not starting and Charger's light blinking..
Exactly what happened to my v570.. power supply is stable when unplugged to the laptop but blinks when plugged in..i took out the battery .. same thing.. any other solutions here?
Mar 21, 2012 | Lenovo IdeaPad Z570 Notebook
Lenovo IdeaPad Z560 Notebook Logo
1,024 people viewed this question
Top Lenovo Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
efs_perpends
efs_perpends
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
