Try to avoid giving treats to your cat if possible. Most treats are very poor quality food. Instead, you might want to give them a quality soft can of cat food like Natural Balance as a treat every so often.
Treats are just a part of the fun that your cat loves. But, that does not mean you are providing it in higher amounts. It should not be more than 10% in a day. Rest 90% should be a proper food that is filled with nutrients, vitamins, and other necessary enzymes that will let your cats leave a healthier life.
You must also check out for Teacup Persian Cats for Sale and get the best ever ways to get better ways in which you can feed your cats.
It is important to treat your cat, however numbers as many as 40 - 50% of cats suffer from obesity - You should ensure that the amount of treats you give your cat do not exceed 10 % of its daily food intake.
SOURCE: Is it ok to give my cat dogs treats?
It is not advisable
to give your cat dog treats as they both have completely different nutritional
needs.
SOURCE: Does the age of my cat madders when it comes to giving it treats?
The age of your cat does matter. Cats have different nutritional
needs at each stage of its life for instance older cats with considerably
sensitive teeth are advised to eat softer treats. You should always fit the
right treat for you cat at any stage of its life.
By your question I can tell that you're pretty new
to the cat growing business. You don't
have to give him treat you want to give him because you want your cat to be
happy and you want to reward him when he does good things, it is also a very
good way to discipline your cat.
I recommend you to store any treat bag in a cool and
dry environment. Make sure that you seal the bag after you open it in order to
maintain the treats as fresh as possible.
Yes absolutely, there are many things you can teach
your cat to do with the right reward. For instance you could move the treat
over your cat's head and when he will look up for it, he may end up sitting
down, you should try repeating it a couple of times until he sits down, just
then give him the treat.
The most important rule you'll need to remember is that the treats
should never be more than 10 percent of your cat's total nutrition.
It is not advisable to give your cat dog treats as they both have completely different nutritional needs.
