Hi
No the new Quinny Zapp Xtra sun canopy is part of the seat fabric.
If you wish to turn your standard Quinny Zapp into a Quinny Zapp Xtra you need to purchase the Quinny Zapp Xtra seat unit as an accessory from your local retailer as it will have the seat frame and the adaptors required to fit it into the chassis you have.
Visit www.quinny.com to find your nearest retailer.
SOURCE: quinny zapp, how to open
I find to fold it, I place my foot on number 3 and push a little then press number 2 and 1 and the same time and fold the seat unit. Then just push down ontyo it untill t is fully folded. I find it to difficult to press 1 then 2 then 3 - 3 always gets jammed if i follow their instructions.
To unfold pull number 3 untill it clicks then nfold seat unit an click the middle handle - hey presto buggy shuld work :)
i thk the instructions tey give a more work than needed.
SOURCE: how do you fold down
the steps are numbered 123 on the stroller. press the big round button numbered 1 on the right side (i think), which is located where the handle meets the main part of the stroller. Press the big round button numbered 2 on the other side. After you press button 2, you should be able to fold the handles (both of them together) forward, swinging the handlebars out in an arc until they're nearly touching the front wheel, on the ground. Now, step 3 is the difficult one--you've got to release the catch numbered 3 (underneath the seat, directly beneath where the baby's bottom goes) and then slide the ring forward, along the rod underneath the seat, toward the front wheel. If you can get it going, the rest will happen very smoothly, and the stroller will fold very compactly. It's difficult to describe, but once you get it, it's a cinch after a little practice. Good luck!
SOURCE: can I purchase a new wheel for quinny zapp
I asked the same question at the Baby on a Budget store i purchased my Quinny Zapp from and they advised me the only place to buy accessories or parts from would be via the Quinny website!!
SOURCE: where to get attachments to attach maxi cosi onto quinny
ebay or direct from dorel
01842 763 281 (Mon – Fri, 8:30 am to 4:30 pm
SOURCE: hi, quinny zapp
Here is the US distributor of parts for all Quinny Strollers...
Dorel Juvenile Group USA
Canton Commerce Centre
45 Dan Road
Canton, Massachusetts, USA02021
(781) 364-3100
(800) 544-1108
