Televison & Video Logo
Anonymous Posted on May 14, 2012
My dvd player won't play dvd
My dvd player is a Sony DVD Player DVP-SR200PB and suddenly it stopped playing any dvd, claming error every time.
Anonymous
Level 3:
Top Expert:
  • Master 14,553 Answers
  • Posted on May 14, 2012
Anonymous
Master
Level 3:
Top Expert:
Answers
14553
Questions
Helped
2715214
Points
48227
Likely if cannot read disc, or no disc or error, that unit has either dirty or bad optical pickup.
  • Anonymous May 15, 2012
    and should i buy a dvd cleaner disc or will it damage the player?
5 Related Answers
Anonymous
  • Posted on Dec 21, 2008
SOURCE: Sony DVP-NS57P all region
Try this,
1) Plug the DVD Power Cord to the wall jack, but DO NOT Turn On the player;
2) With the Remote Control, press: Display, Top Menu, Clear and Power;
3) It will enter in the Service Mode;
4) Choose option 2 and then 4;
5) It will ask for an Input Code and Current Code (its 5 spaces), press 1245 and then Zero;
6) Leave all Zero erasing 1245, and on the bottom field all Zero too, then press Enter;
7) So the DVD Display will show a Zero (all Region-Free),     then press Power to Turn Off.
Anonymous
  • 6 Answers
  • Posted on Jun 22, 2007
SOURCE: player won't play any disks only says CANNOT LOAD DISK
change the way you connect the dvd player to your tv
Anonymous
  • 398 Answers
  • Posted on Sep 01, 2007
SOURCE: sony dvp ns50p dvd player
If you are using the s-video jack to connect the DVD to the TV, the jack could be loose or the wire could be bad. The s-video cable has 2 signals, the black-and-white (luminance) and the color (chroma). If the chroma signal is not getting through, the picture will be in black and white.
Anonymous
  • Posted on Sep 04, 2007
SOURCE: DVP-NS305 DVD Player
Your system is in child lock mode. I had this exact problem this week. You need to put the system into standby mode and then press return, then enter then on/off and it will be unlocked.
Billy Rogers
  • 3 Answers
  • Posted on Oct 12, 2008
SOURCE: unlock region code on Sony CD/DVD Player DVP-NS57P
I don't have a solution, but I know that the one about "press Display, Top Menu, Clear, Power" doesn't work.
37helpful
5answers
Sony dvp-ns57p plays cds, not dvds
COMO PUEDO DESBLOQUEAR EL VIDEO DEL DVD
Sony dvd player error t99
Hi Nemegraff,
I have a Sony DVP- NC665P dvd player. I burned a dvd movie and noticed I could not play it on my player. I was getting a display code "T99". I believe the "T" stands for time on the dvd.
Anyway, to my surprise, I found out if I press the "top menu" button on my remote, the dvd will start from the movie's main menu screen....then just hit enter or play and the movie will play. My problem is solved. I hope this helps you.
best,
larry
My Sony dvp NS710H isn't playing most standard, well conditioned DVDs.
Hello
Just clean its laser pickup lens, by inserting a lens cleaning disc in to, and play it at least two times. If it doesn't help you, the laser pickup unit should be replaced. The lens cleaning disc can be bought from most of the electronic sparepart selling shops at your town, and won't cost more.
Sony portable DVD player dvp-fx970 won't play dvd
Use lens cleaner TDK or wash dvd disks with hot tap water then block off the water drops.
4helpful
Tray locked on sony dvp-ns77h dvd player
If the Sony DVP-NS77H DVD player displays "TRAY LOCKED" and you can't eject a disc or open the tray, try the following - First turn the unit off. Then, while holding down the eject, play and stop buttons simultaneously (on the front of the DVD player), turn the unit on with the '/O button (also on the front of the player). This released the locked tray for me.
Suddenly "cannot play this disk" on Sony DVD/CD..every DVD...CD's work!
I have the same problem. I have a 5 year warranty from the company I purchased the unit from. I am not sure if they will replace it or not. I am reluctant to buy another one with this known issue. We have enjoyed the unit for nearly 3 years with no issues.
Playing DivX format on Sony DVP NS530 DVD player
No Sir, You can't upgrade DVP-NS530 to play DivX format. This player has no ability to play DivX nor it can be upgraded.
Sony dvp-ns425p will play regular CD, but won't play any DVD
just open the player (4-6 screws) and clean the lens. I had a similar problem (plays VCD, CD but no DVD - tray will open immediately). It worked afterwards
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
