Question about Samsung 50 in. Plasma TV
Autuotune samsung 42 inch plasma
When I try to put curser on autotune icon it jumps over it, meaning I cannot get into the menu to autotune
    Top Expert:
  • Samsung Master
  • 12,223 Answers
Please follow this step:
you have customized the picture and menu settings on your Samsung TV only to find that they keep reverting back to their default positions, this is because your unit is in what is referred to as "Shop Mode." This is the demonstration mode used by electronic retailers to show potential buyers all the features a Samsung television supports. Press the "Info" button on your remote control, and if under the "Picture Mode" heading it reads "Shop Mode," hold down the "Menu" button on the TV itself until the screen reads "Dynamic Mode." This has changed the picture mode to one of the pre-set positions. You may now change any settings you'd like.
God bless you
Posted on May 14, 2012
5 Suggested Answers
Anonymous
SOURCE: Blue pilexlation on 42 inch samsung plasma
How does one go about adjusting the voltages? Thank you
Posted on Jul 20, 2008
GySgt2u
  • 63 Answers
SOURCE: 42 inch plasma wont turn on
I may have the fix.... Fixed two of my 50 inch plasmas that stopped turning on 1 year after I bought them. They both wouldn't turn on.... LOL Just gave me the black screen of death and a red blinking LED when I tried to turn on. I have pics and step by step instructions. Your time and under 40 bucks is what you'll need. I fixed both my sets for 80 cents. You can fix yours too.... I too got the it would be better to replace it than to have it fixed lie told to me too. I held out to the bitter end. Glad I did....
Posted on Feb 08, 2009
roety
Eric Rotmil
  • 587 Answers
SOURCE: 42 inch samsung plasma tv black vertical lines
Hi, Depeending on the thickness of the lines matters. If the lines are Black and about 1-2 inches thick it may be a bad bottom buffer board or a bad panel (screen).
If the lines are thin 1/16 to 1/8 inch it is most likely a bad panel.
You can open up the set and depending on the model, see the thin board/boards running across the bottom with ribbon cables going to the panel. You may be able to attempt reseating the ribbon cables, but be careful as some retainer plugs break very easy.
If the lines are thick black and the reseating doesn't correct it you may be able to buy the coresponding buffer. Unfortunately some bottom buffers are actually part of the panel. If you are not comfortable taking it apart then call a professional but be aware labor charges start around $200 not counting parts, panels start at $600 up to over $1000
hope this helps
Thanks
Eric
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Posted on Aug 19, 2009
Jim Krause
  • 1779 Answers
SOURCE: samsung plasma 42 inchs with sound no picture
Most likely your Y Sustain panel has gone bad. I would have a qualified service center evaluate it to be sure.
Posted on Nov 07, 2009
circuitworld
Circuit World
  • 335 Answers
SOURCE: 42 Inch Samsung Flatscreen; 1.5 years old. Won't
First test the wall outlet, try plugging a lamp into the same outlet see if it works. If the outlet works then read the following below. If the wall outlet doesn't work then plug the TV into another outlet.
If its not the wall outlet:
Unfortunately the power supply has a problem sustaining DC output. This can be caused from several fault scenarios. Get someone who is technically savvy and I will show them via e-mail what to test to fix this problem for you. Or you can take it to your local repair center.
Posted on Dec 20, 2009
I have a 42"zenith plasma tv. Been trying for hours to auto tune,none of the channels come in.
What is your input source? Is it Antenna, HDMI, Component or Composite.
The Autotune is only for Antenna input when connected to an indoor or outdoor antenna, if you are connected to a cable or satellite STB then that is what will do the tuning.
Oct 02, 2014 | Zenith P42W24B 42 in. Plasma Television
HAVE SAMSUNG 51 INCH PLASMA I BOUGHT 10 MONTNHS AGO THE PICTUE STARTED JUMPING WEEK AGO I CANT FIGURE OUT PROBLEM
It sounds that the problem is with its main digital processor board. It is best to contact any service technician to confirm.
Nov 14, 2013 | Samsung PPM42S3 42 in. Plasma Television
Would like intruction manual for 42 inch samsung plasma-serial no-Z5RX3STS400333K
http://www.samsung.com/us/support/detail/supportPrdDetail.do?menu=SP01&prd_ia_cd=02010200&prd_mdl_cd=&prd_mdl_name=HP-T4254
Mar 07, 2010 | Samsung HP-T4254 42 in. Plasma Television
Cannot access 'channel'' menu in samsung DTV menu to carry out retune. The menu jumps from 'sound' to 'setup', the 'channel' icon is greyed out and cannot be accessed.
This is becouse you had done some Channel Child Lock first open all child lock than try to tune channel.Or possible that you are in some other input mode.select TV mode than you can try.
Jan 22, 2010 | Samsung HP-R4252 42 in. Plasma HDTV
Emerson 42 inch plasma (Walmart special) need code
Try the Samsung codes that are in the manual for the remote. The Emerson is a rebadge of a Samsung. My Dish remote worked poorly with the Emerson codes but the first Samsung code I tried worked beautifully! :)
Nov 28, 2009 | Emerson Televison & Video
Samsung plasma 42 inchs with sound no picture
Nov 07, 2009 | Samsung PS42P2S 42 in. Plasma Television
I have a 42 inch plasma and teletext wont work any
A factory reset made teletext available again on digital channels.
When on standby, push on remote in quick succession <info><menu><mute><power> buttons. Follow onscreen menu to option 12 (reset) and select. Be aware that you will have to tune in all analogue and digital channels again.
Jul 22, 2009 | Televison & Video
42 inch samsung plasma screen is half blacked out
the problem lies in the y or x board just replace the on thats acting up and you should be ok
Dec 31, 2008 | Samsung SPN4235 42 in. Plasma HDTV
Samsung  50 in. Plasma TV Logo
146 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
