Model PSI23SGRB
SOURCE: ge profile side by side 'fridge
Evaporator fan motor and main Pcb , the fan motor goes faulty and then burns out a resistor on the main pcb at the back.
SOURCE: Freezer side cold, frige side warm
Defrost heater is open behind back wall. order new heater #wr55x10101 remove 4 screws 2 bottom, 2 top behind light shield, defrost freezer so ice is off of evap, replace heater with new one.
SOURCE: freezer door wont seal and stay closed
Your pushing air from the fridge part over to the freezer door when you clos it,the only thing i can suggest is make sure that the seal (which is magnetic) is clean and not falling apart,inspect it all around the door,and when closing the door i would close it gently.
Hope this helped.Let me know by rating me or
for more help go to live chat.Thanks
Len West
SOURCE: GE Side by Side freezer cold but not freezing, fridge is warm
you might have a defrost problem, timer,heater or bimetal when the coils freez up they dont cool enough .
SOURCE: freezer door pops open when fridge door is closed.
well u need to check the rubber of ur freezer ;s door .some damaging in the rubber is causing the problem.
check to see if there is frost building on the lower back wall in the freezer if there is frost the unit is not going into defrost
There is no frost in the freezer. Freezer seems to be running fine, but it is 17degrees instead of the 0 degrees it should be.
Fridge smells like something burned-out.
