I bought a sansa e270 n connected it to my pc n it got virus from there now i want to format it can i do it like any other drives or is there any other specific way to do it n i also want to put rock box in it, will it be a wise decesion?
I'll be greatly thankfull 4 ur answers
Tushar
SOURCE: sansa e270
To obtain the driver for your sandisk device go to http://www.sandisk.com/DriverDownload/index.asp and find the driver for your device..and then connecct the device on the back of your computer...it should work properly..if you are still having any problems..let me know..i would be more than happy to assist you..
Please rate accordingly
Thank you
Computerrep
SOURCE: driver for sansa e270 for win xp os
Install Windows Media Player 11. The Sansa drivers, and MTP system, are part of WiMP10 / 11. Windows XP "out of the box" has WiMP9, which may be your problem.
The Sansa can function as a flash drive in MSC mode, but your files transferred in MTP will not be available on the PC side.
The Sansa does not require specific drivers from SanDisk, as it's integrated into WiMP.
Go under menu, setting and change the device to MTP or playforsure..
Let me know if that works
Thanky you
Computerrep
SOURCE: sansa e270 it lost driver
Go to Sandisk's website and get the software you need. If the reinstall fails:
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
SOURCE: probles with formatting and resync sansa e270
hi! you can try reformatting by activating the keylock and then press and hold the record key while turning the power on. it will go to the recovery mode.
plug the mp3 usb to your pc.
open a notepad apllication and create a new blank file.
save as sansa.fmt and change save as type, it should be All Files. it will create a file with 0 bytes.
you can now disconnect the usb and wait til the mp3 displays formatting.. it will reformat by itself.
SOURCE: sansa e270 ....computer no longer reads content of sansa
Well, the reason you can't see some of the songs is because they are in a hidden folder. To access the hidden folders, you have to go to computer, then folder options, and check unhide hidden files and folders. If you go back to sansa, you should see a light colored folder that is titled music.
