Sony CMT-M100MD\W CD Shelf System Logo
olaf siemon Posted on May 13, 2012
At my sony cmt-m100md it allways show blank disc after inserting a md. I am not shure if the discs I have allready been recorded so I did a test recor but when I try to play it aalways shos blank disc
After I inserted a md the display shows blank disc. Am am not shure if the discs i got allready been recorde so I did a test record from tuner. But when I tried to play it showed blank disc again. Can anyone help?
David Roberts
Level 1:
Habit-Forming:
New Friend:
  • Contributor 38 Answers
  • Posted on May 13, 2012
David Roberts
Contributor
Level 1:
Habit-Forming:
New Friend:
Answers
38
Questions
0
Helped
16742
Points
98
Laser disc reader may be faulty
2answers
My MDS-E10 Has Been Having Problems Lately. I Own Hundreds Of Mini Discs That I Have Recorded Music On Several Years Ago. Everything That I Have Recorded On These Mini Discs (Years Ago) Play Fine With No...
hi there is nothing to do by yourself. you need to take your md player to the next authorized service. seems the optical device that reads the discs has worn out, compareable to turntables you need to change the `needle` ;)
Md sony mz-r50 error blank disc
maybe flat cable recorder lense is too short and now it is broken...
Teac md-h300
There is no unit with the name you gave.
Does the unit itself say MDLP on it? If it doesn't, theres a good chance it doesn't support the LP modes and will only playback/recor unit only plays in SP or MONO.
3helpful
3answers
Sony cmt-cp33md,place dic in machine,toc reading shows read error C13,then ejects disc.
The c13 error means that the player is unable to read the table of contents (TOC) on discs any more. If it's an occasional error then you can try switching to TDK blanks as they seem to be easier for flaky players to read, but if it's happening regularly to all discs then your machine is unrepairable due to a total lack of spare parts.
On the plus side, there are millions of MD units now lying unused as folks have moved on from them and as they're mostly worthless people don't generally bother with trying to sell them. Almost every piece of MD gear I own has come free of charge via my local FreeCycle and Freegle groups. Whatever you do, don't buy a used player from anyone: they're all getting on now and the TOC error is an age-related fault which may occur at any time.
If you wish to see exactly what features other machines have then visit the superb equipment browser at minidisc.org. The site is hosted but n longer maintained though so some information is out of date, but it's still the most comprehensive source of free information about MD available.
Sorry here's probably no hope for your player, but I hope that my reply has given you a practical alternative means of solving your problem.
I have a problem with my MD player.on screen showing read error c13.is it easy to fix?
The error means that the player is unable to read the table of contents (TOC) on discs any more.If it's an occasional error then you can try switching to TDK blanks as they seem to be easier for flaky players to read, but if it's happening regularly to all discs then your machine is unrepairable due to a total lack of spare parts.
1helpful
Doesn't accept md's
The manual says "C13/Disc Error: The system cannot read the disc information correctly. mEject the MD once, then insert it again."
It seems this error turns up when the system cannot read the disc properly, one reason for which is a dirty/dusty lens. Try a minidisc lens cleaner if you haven't already.
Tom
1helpful
Spontaneous MD erasure
Well, depending how the content was recorded, there may be a slim chance to recover the audio. To me it looks like TOC was not written successfully, effectively deleting the TOC.
You can try TOC cloning with this 'blank' MD using another MD player, but your track markers will be lost during the cloning. If it works, at best you will end up with ONE long track. Then you can edit and reset your track markers.
It may be also be a good idea, to try the JE440 carefully with junk content to make sure it still works ok when writing TOC. You may have an intermittent problem too. I'd be very careful editing MD in this unit until it has been confirmed the TOC writing works ok. You may want to check the over-write head assembly and the cable that connects it. Sometimes these cables develop hairline cracks causing intermittend write action.
Check out www.minidisc.org forum for TOC cloning.
Good luck recovering your audio.
Sony MZ-N505 - says mini disc is blank
Hi- it sounds like the record head is bent or needs adjustment. I do repairs on Sony minidiscs, so you may contact me at: [email protected] for help.
Jacques
2answers
Recording error
mine was doing the same thing.and we found out that if you recorded something and dont finalize it will not recored anything else till you finalize what you recored then it works again
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
ZJ Limited
ZJ Limited
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
