I can scroll photos on camera, but when I try to download to the computer there are no photos. The Canon file when opened claims to contain 3 items, but only has two visible files. Neither CF cards are working and this all happened in an instance. Worked one time but not the next.
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
SOURCE: Cannot transfer images from my Canon DSLR XTi to my computer
Having same issue as above - I thought it was my cable so I ordered a new one. The camera attempts to 'speak' to the pc - and then the Windows box pops up not recognising the USB installed device....I also uninstalled and reloaded the Canon software (had camera for 18 months and only started this rubbish a month back) - was about to re-laod my entire PC - thankfully I saw it was not only me.
Will send mine in for a Firmware update / service.
SOURCE: Canon 10d digital camera Err 02
Most likey your problem is the cf card reader when ever the camera was made they could have not heated up the board all the way causing a cold solderjoint after time this joint becomes week and gets disconnected on the back side no visual damage is seen causing you the error you are getting. best thing to do is take it to a repair shop and have them fix it or the manufacture should repair it for free because there is no fisical damage.
SOURCE: Hi...I can't download pics from my canon powershot
You need to find your original Canon solutions software disk and reinstall it. But if you can't find it, please see the following blog article, as it describes the use of a card reader as a much easier, faster, and less error prone way to download your photos. In fact there are several important reasons discussed in the article for using a card reader vice downloading from the camera. USB Card readers are also very inexpensive these day, with cost virtually not an issue:
http://camerarepair.blogspot.com/2009/01/how-do-i-download-photos-or-pictures.html
SOURCE: Canon Rebel xt does not accept CF cards for no apparent reason
It sounds like a bent pin in the CF slot. This is not a do it yourself fix. Take it to a repair shop.
SOURCE: "There is a problem with the CF card Replace the CF card"
You need to format the card in your camera for it to work properly.
