Wall opening unit 10,000 btu's
SOURCE: Emerson Quiet Kool Drips Water into the house
depends on the unit. you will probably have to slide it out of its case and clean the outside part . there should be a hose that goes from the inside to the outside for the water to go out. this hose may be clogged, trapping the water inside. as i always say a picture of the unit always helps so i can identify it and tell you what to do to try and fix the problem. email the pics to [email protected]
SOURCE: Emerson Quiet Kool A/C Filter
If you know where to find a filter for a Emerson Quiet Kool--Model # 18DD4H-EE
Serial # 21A 927552 Please let me know
[email protected]
Thanks
Ed Beverley
SOURCE: ac has a loud hard bang when compresser kicks in
The internal motor mounts for the compressor are broken, that is the loud banging.
At 17, new one is more energy efficent.
SOURCE: BTU's on Emerson Quiet Kool A/C
AC Type Thru-Wall/Window Cooling Capacity 10000 BTU/hr Energy Efficiency Rating 9 EER Fan Speeds (Cooling) 3
SOURCE: I need a replacement front panel for an Emerson
Type in the brand name, go to the website, and type in all the model#,s and surf..
