I turn it on the screen has a bunch of lines in it i have to turn it on and off 10 or 15 times and it clears up can i fix this
SOURCE: magnavox tv trouble
Intermitant problems on old TV's are almost always poor solder connections. If you have done some soldering before you may be able to repair yourself, if not i wouldn't try to learn on this. Begin by gently tapping components on the circuit boards while the TV is on good chance you will tap an area and it will shut right off. make sure you are using something insulated and non-metalic. if you find a spot that is especially sensitive get to the bottom of that circuit board and begin soldering. this is probably the most likely cause but there are other possibilities. If you attempt this do be very carefull. My honest suggestion is to have a pro do it, if it just solder work it shouldnt cost that much maybe around a 100 to 150 if you can take it in somewhere.
SOURCE: Phillips/Magnavox 9P5544C102 white raster and shuts down
This denotes a problem called blooming the horizontal lines you see are called retrace lines this is caused by the increase in anode voltage which could be caused by an increase in HV section current which trips the overcurrent protection dircuit and turns the TV off.If you do not have electronics experience I would suggest taking the set to a TV repair shop.
SOURCE: tv problems
i have a sony hdtv 60" and when I try turn the tv on the power light flashes 5 times green then it turns red
SOURCE: I have a Magnovox HD TV Progressive Scan (Floor Model) TV
You can find a replacement Philips/Magnavox fresnel screen, in stock, for this model (51MP392H/17) at this following link from a major parts distributor:
Philips / Magnavox 51MP392H Replacement Part Fresnel Screen
And here's a link for the Lenticular (middle) Screen, if needed:
Philips / Magnavox 51MP392H Replacement Part Lenticular Screen
