Wiring diagram for 2004 sierra bose audio amp
I would like the pin-out of the amplifier. It is a "BOSE" amp assembly #5600
5 Related Answers
Anonymous
  • 3 Answers
SOURCE: Audio trouble with Bose System
make sure you have connected the rca cables from the 'out' of the TV to either of the video 'in' channels or try the tape 'in' on the bose. hope this helps. which bose are you using?
Posted on Aug 13, 2007
SOURCE: '05 Chevy Z-71 w/ BOSE stereo upgrade. How can I wire the BA-200 ?
Unfortunately, it's not as simple as a crossover. Bose gets its name from making complete systems - meaning - Bose speakers work right because the amplifier is custom built for those speakers, and the deck is custom built for the amplifier- all Bose from beginning to end. The only way to bypass any part of a Bose system is to bypass the whole system, including amp, deck, subs, speakers, eq's, and start over from scratch, unless you are an electrical engineer and can meter components and evaluate them. Bose often has 1 or 1/2 ohm speakers which will not work with after market systems.  If you go to a Bose store, the only system that sounds good is the lifestyle system because it is Bose from beginning to end, just as an example. They are either cheaters or geniuses
Posted on Oct 17, 2007
Anonymous
SOURCE: bose 901 v1 adding a amplifier
You may connect an additional amplifier to the Rec Out or Line Out from your existing receiver.
Please note the Bose 901 equalizer can be used to connect to one amplifier only.
Do let me know if you have any further questions.
Posted on Dec 18, 2007
Anonymous
  • 16 Answers
SOURCE: bac speaker bose 321
The arrays from this system are only designed to run with the Bose Acoustimass / subwoofer, which in turn will only work with the Bose DVD player. If you use them directly to an amplifier, they'll sound poor / wierd and you probably blow the drivers. You might even damage your amp.
Each speaker has 2 drivers firing in slightly different directions. The idea is (when its used with the 321 system), the inward speakers give a mix of front and centre, the outer drivers give a mix of front and rear. A normal amp won't do this....
Posted on Jan 18, 2008
Anonymous
  • 107 Answers
SOURCE: Bose Lifestyle 50 - connection to a non-bose amplifier
The 2 system are completely different your is low level input and its is having only 2 input L and R when those signal they get inside your sub it process through an DSP ( Digital Signal Processor ) and become 5 output to yours satellite cube speakers
The AM6 or 10 are high level input connected direct to any output of any AMP from those signal they convert down to low frequency for sub woofer
Posted on Dec 16, 2008
2004 GMC Sierra 2500HD with factory Bose stereo system but no on-star, put an aftermarket clarion CD/DVD player in it over 2 years ago i put in the adapter for making the Bose factory system work and
either your connectors need cleaning or maybe a break in the wiring. Is there on spot where both wires come together if so check there.If there is any plugs, pull them apart and clean them with contact cleaner
Dec 15, 2014 | 2004 GMC Sierra 2500HD
04 Infiniti sedan w/ factory Bose. Front speakers are not working (no sound at all) and I adjusted fade all the way both ways. Back speakers are fine. What's up?
If the rear speakers are fine, perhaps I can narrow this down. Fuses must be OK. Steering wheel audio controls connect to the audio unit which has a preamp function. The W/BK outputs connect to the left front inputs of the Bose speaker amplifier; the GRN/RED outputs connect to the right front inputs. Your ear test confirms the front door speakers are not working, therefore there is no front door output from the amplifier. The amplifier stages for the front doors may not be working or no front door amplifier input is being received from the audio unit. The fader and balance controls do not show on the diagram so must be on the front panel. They could be defective. There is a remote possibility of broken/disconnected wires
Sep 07, 2012 | Sony 2003 2004 03 04 Infiniti G35 Bose Am...
Wiring diagram for bose 28060
Infiniti QX56 Car Radio Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Yellow
Car Radio Accessory Switched 12v+ Wire: Purple
Car Radio Ground Wire: Chassis
Car Radio Illumination Wire: Red/Blue
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger Wire: Green/White
Car Stereo Amp Trigger Wire: Green/White
Car Stereo Amplifier Location: To the right of the steering column behind the BCM.
Left Front Speaker Positive Wire (+): Blue/White
Left Front Speaker Negative Wire (-): Blue/Red
Right Front Speaker Positive Wire (+): White/Black
Right Front Speaker Negative Wire (-): Blue/Black
Left Rear Speaker Positive Wire (+): Gray
Left Rear Speaker Negative Wire (-): Black/Yellow
Right Rear Speaker Positive Wire (+): Orange/Blue
Right Rear Speaker Negative Wire (-): Red/Blue
Jul 08, 2012 | Cars & Trucks
I want to connect my new amplifier bose ...., my car (audi a4 2003mod. ) have on the normal sound sustem with the concert audio..., i fix all the speakers from bose on my car and now i must put out the old...
Bose is premium gear at premium prices so it isn't wise to take chances - you should contact Bose to obtain a connection diagram and then you could find it isn't suitable to use the existing Audi wiring and you should wire afresh from scratch. Obtaining an Audi diagram will help or perhaps a connection diagram for the original sound system.
Sep 29, 2017 | Car Audio & Video
Bose audio input receiver cable 15 pin
You can buy it on ebay but it's cheaper just to make one. If you can solder, all you need is a female 15-pin d-type connector and a bunch of speaker wire. Here is a diagram of the connections.
Jun 24, 2009 | Bose Acoustimass 10 III System
Bose 802 C series II to Yamaha rxv 459 Amp
Tech data sheet with diagrams:
http://www.bose.com/pdf/professional/802III_techdata.pdf
In a nutshell, the controller would go between a preamp Stereo OUTput and a dedicated amplifier INPUT. You can't use Bose 901 or 802 EQ in a multichannel setup without separate amps for the Bose speakers.
The Bose 802/901 family uses full-range speakers instead of traditional woofer/tweeter combinations, so they compensate for the response limitations at the extreme frequencies by using severe electronic modification of the program material. Hence, they are a system, functionally inseparable, but the results are outstanding. Consequently, they need a dedicated amplifier so they alone get the processing provided by their electronic component.
In a vanilla stereo configuration you would just put the controller/EQ into a Tape Monitor loop but multichannel sound and digital sources won't work that way.
You should be able to draw off the (assumed) Front L&R channel preamp signal from the MD/CD-R or DVD-R Audio Out (REC) jacks (*). Run that to the Preamp In (or whatever it's labeled on the Bose EQ/Controller). DO NOT run a return RCA pair back to the Receiver as Bose-processed signals will not play well with non-Bose speakers. (*) Run the Output of the Bose EQ/Controller to a powerful separate amp for the Bose 802/901's. I use two channels on a Carver multichannel AV-406 amp but a stand-alone Carver MT-200T also works well. A good clean 100 watts/channel should suffice at home.
* If possible, choose the recorder loop you are NOT using for something else. If you're using the MD/CD-R or DVD-R Audio OUT for a recording device just get some RCA splitters to share the Stereo signal between the Bose and the device at the same time. However, once you select monitoring of that recorder two things will likely happen - 1) you'll lose the Bose and anything digital in the receiver will be disabled.
It's the nature of the digital beast that analog monitoring gets in the way of DSP.
Of course, if anyone who reads this has a receiver with individual analog Audio Outputs for the various 5.1 channels (as I do), the solution would be to draw off the Front L&R channels to the Bose EQ and downstream amplifier and the rest would be the same but without Recorder Loop limitations.
Apr 28, 2009 | Bose 901 VI Main / Stereo Speaker
Car speakers pop when on/off new stereo preamp out to Bose amp
Hi mate
this maybe caused by a positive and negitive wire touching somewere down the line!
just follow up your wires and check
Feb 16, 2009 | Bose Car Audio & Video
Bac speaker bose 321
Nov 28, 2007 | Bose 3·2·1 II System
Oct 15, 2007 | Audiovox BA200 Car Subwoofer
253 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
