Question about Canon EOS Digital Rebel XS / 1000D IS Digital Camera
Canon Rebel camera wideangle lens settings?
Which is the best setting to use when using the wide angle lens?
Posted by Frank Murphy on
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Canon Master
  • 102,366 Answers
That depends on what you're taking a picture of. The best setting for a landscape picture won't necessarily be the best setting for a group portrait. You might want to use different settings for a daytime landscape than for a sunset. That's why the camera offers different settings. The camera is a tool. You're the photographer.
Posted on May 14, 2012
5 Related Answers
Anonymous
SOURCE: error 99 msg on new canon
I am getting my Sigma lenses upgraded. Only cost to me is shipping.
Uncle Dave
Posted on Jan 14, 2008
Anonymous
  • 153 Answers
SOURCE: Setting to shoot black and white
No, you can reduce the saturation but not go mono, (in the parameters settings)
You will need to adjust the colour balance and convert to mono in photoshop (or similar)
There are quite a few articles on the web regarding shooting in IR with the rebel, best results can be obtained with a modification to the camera http://ghonis2.ho8.com/rebelmod.html (reversable by using a IR cut filter for non IR shots) as it contains quite a strong IR filter which means although it is possibler without modification exposures will be quite long with IR filters and focusing difficult as the auto wont work and you will be able to see very little trough the viewfinder once the IR filter is on.
Here are a few articles, they may not relate to your exact model but all the eos cameras are somewhat similar.
http://photo.net/equipment/canon/digital_rebel_xt/
http://diglloyd.com/diglloyd/free/Infrared/index.html
http://www.astropix.com/HTML/I_ASTROP/EQ_TESTS/INFRARED.HTM
http://astrosurf.com/~buil/350d/350d.htm
people who will mod the camera for you.
http://www.lifepixel.com/ (also sell replacement sensor filters)
http://spencerscamera.com/default.aspx
Im sure there are many others.
Best of luck
Posted on Jun 08, 2008
Anonymous
  • 61 Answers
SOURCE: Canon Rebel XTI W/stabilizer lens
Hello bbridges,
Wow, you asked a REALLY open ended question. But here is a good starting point for Manual mode shooting.
Daytime (Full Sunlight) ISO: 100 (or 200-400 to capture fast motion)
F-Stop: Depends on how much depth of field (DOF) you want The lower the number, the blurrier the background. The higher the number, the more everything in the frame is in focus. Shutter Speed: Depends how much motion blur you want. The higher the number, the less blur you get.
Nighttime (Track Lights) ISO: 800-1600 F-stop: Again, depends on how much DOF you want Shutter Speed: Depends how much motion blur you want. The higher the number, the less blur you get.
Remember when you are panning to capture something in motion, keep on tracking (moving with the subject) even after you have released the shutter. It will help your stability reduce the chances of unintentional blurring.
My suggestion is to go to dpreview.com or stevesdigicams.com and do some rooting around in the forums. They both offer friendly and helpful advice. Also, check out webphotoschool.com
Better yet, experiment with your camera. Pick a time of day and take a series of photos of the same thing, and only change one setting at a time. Make note of what photo number you're on, and what setting you changed (and what it is). Then, when you look at the photos on your computer, match the photo numbers up with the chart you've made, and you'll begin to see a pattern. This is one of the faster ways to learn by trial-and-error. And, this method sure beats randomly shooting and just spinning the dials hoping to get something good. Try to predict the outcome of the shot before you shoot it. Ask yourself what the photo should look like (light? dark? just right? everything in focus, or just the subject?)
As for your lens, check to make sure the Auto Focus settings in your camera menu as well as on the camera are set correctly. And if all else fails, turn off the camera, remove the battery, remove the lens (in as dust-free environment as possible), and then put the lens back on, the battery back in, and turn the camera on again.
Happy shooting, and hope this helps!
**If this response helped you, please take a moment to rate it — thanks!
Posted on Mar 13, 2009
dennis bullard
  • 4090 Answers
SOURCE: I am having trouble photographing birds. Do I use
Use the telephoto lens.. wide angle will tend to distort the image and provide too much detail( distraction) around the object of interest. Bird pictures become more interesting when they are mainly of the bird. So when you look through the lens, zoom up to the bird to the point where you have it nicely framed with none of its parts outside of the frame.
Capture the whole image.
Wide angle lens is mainly used for scenery or where you want to take a group photo or panorama.
Please rate my help++++Thanks for using FIXYA
Posted on Nov 29, 2009
Testimonial: "Thank you for your help. Do you have any suggestions as to what settings ie Automatic or AV etc and also the ISO, shutter speed etc, Thanks"
Gary Maitland
  • 117 Answers
SOURCE: What is error 99
What wide angle lens is it need f number it may be to old to work on eos 400d
Posted on Jan 11, 2010
Every picture I take has a line going through every picture
Have you checked you lens, there could be a hair line dust scratch on it. Or you have it set on a setting that helps with leveling...yes camra's do have them.
Aug 27, 2013 | Polaroid Studio Series .43X HD Wide Angle...
Wide angle lens
You can save a little money with a third-party lens like a Sigma ( http://www.adorama.com/SG1020EOS.html ) or a Tamron ( http://www.adorama.com/TM1024EOS.html ).
Jul 16, 2013 | Canon EOS 600D Rebel T3i Digital Camera...
How to connect vivitar wide angle lens and telephoto to canon t2i
make sure the vivtar lens is "58mm" diameter (shoutstate this near the fron of the vivtar lens) then it should be a question of screwing the lens on top of the other lens. not the best way of getting wide angle shots as the 18-55 is pretty soft in focusing already and adding another inferior lens will make it look poor. if you don't want to buy a lens i would suggest investing in a tripod and take multiple shots with the 18-55 and stitch them together with a photo editing tool like photoshop
Dec 30, 2010 | Canon EOS 550D Rebel T2i Digital Camera
I HAVE A CANON EOS REBEL T2 35MM FILM CAMERA AND AM PURCHASING A CANON TI1. CAN I USE THE SAME LENS ON BOTH CAMERAS?
Yes, you should be able to use them. Be aware, moving to digital there is a 1.6 crop factor. The means your 100 mm lens will have the field of view (FOV) of a 160 mm. No, it does not mean it is a 160 mm it is the fFOV is the same as a 160 mm. Also, at the other end is were you will most want to purchase a wide angle lens.
Example: your 28 mm film lens now has the FOV of 44.8, not wide angle. As you can see wide angle is where the move to digital crop sensor cameras lose out. To get back to wide angel you would need a 17 mm lens, that would give you 27.2 mm FOV.
To figure FOV take the lens multiply it by the crop factor. On a Canon it is 1.6, on a Nikon it is 1.5, the 4/3 sensor is 2.0.
Nov 01, 2010 | Canon EOS Rebel 2000 with 28-80 lens 35mm...
How to zoom in using Canon EOS Rebel XS?
Zooming is done from the lens on a DSLR, assuming you have a zoom lens on the camera. For example, if your camera came with the 18-55mm lens, you should see the numbers 18, 24, 35 and 55 on the lens barrel with a white index line next to one of the numbers. Turn the barrel to move a different number next to the index line. 18mm is wide angle, 55mm is 'zoomed in'.
Mar 12, 2010 | Canon EOS Digital Rebel XS / 1000D IS...
I am having trouble photographing birds. Do I use the telephoto lens or the wide angle lens? I also have a macro lens for my Canon EOS 400D SLR Also what settings do I take them at. I have a tripod but the...
Nov 29, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
How to attach wide angle lens to telephoto
I don't understand your question...a wide angle and a telephoto are two different lenses.
Nov 12, 2009 | Canon Digital Rebel XTi 10.1MP Digital SLR...
Photos have a black band at top and bottom. This has never occurred before on my Canon EOS Rebel XT. I use auto mode for all functions and have not changed any menu settings.
If you use the lens in wide and the f lash is not wide as same (if the lens is 18 wide and the f lash is 28 wide ) you will not get good photo so if use 18 mm wide lens then use 18 mm wide f lash and ( i have told about external flash )
Nov 04, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Lens
Have you ever heard the expression "Good, Fast, Cheap ...pick any two" ? Well, it's that situation. The kit lens is cheap, and it has a good zoom range (including wide-angle) but it's not very high quality. The best lens for you is probably the 17-55 EF-S -but it is $1000. It is a great lens, and it's efficient and light sensitive, along with image stabilization. Without knowing your budget, I would also recommend the 28-135 EF IS, but it doesn't cover the wide angle range. That one is $400. There's also the 17-85mm, which also has Image Stabization. That one is about $500.
Aug 09, 2007 | Canon Digital Rebel / EOS-300D Digital...
Nikon d50 and lens
I don't have this kind of camera myself, but on my Canon D350 there is a switch on the lens that sets manual/automatic focus. Mine is marked MF/AF ans is just a simple switch. Check to see if this might be the case on yours, too. Also check the contactts on the lens and camera to see if they might be dirty. And be very careful not to get any dust into your camera housing! -Chris
Mar 06, 2007 | Nikon D50 Digital Camera
Canon EOS Digital Rebel XS / 1000D IS Digital Camera Logo
120 people viewed this question
Top Canon Cameras Experts
old marine
old marine
halotheracer
halotheracer
Steven Wander
Steven Wander
Are you a Canon Camera Expert? Answer questions, earn points and help others
