When the electronic model number 4c-337b is pressed all the machine will do is beep
SOURCE: Singer CE200 bobbin winder
I fixed it by going to the free web site.
Thank you so much
Joe Varnum
SOURCE: Beeping Sewing Machine
Your problem is most certainly with the buttonhole switch. Firstly: Look if the buttonhole lever, left back of machine, is push up in position. The beeping sound is a warning message. Secondly Remove the light cover, left of the machine, loosen back screw and remove left hand screw completely. Check for a small black electric switch, follow the brown and green elecrtic wire, just back of the light. If you push the BH lever up and down the switch finger should also move up and down. If it stays down, the machine will not work and give a beeping sound. If the switch finger is stuck, push it up with the BH in top position. Hope this will help you
SOURCE: Singer 2638 - three "beeps" when the foot pedal is pressed
when I stiches any cloth the thread gets lose on backside of cloth or some times it breaks how to solve is problem I am not understanding please help me.
SOURCE: electronic sewing machine (singer 7442) will not sew buttonhole
Ensure that you have the buttonhole lever all the way down until it doesn't go down anymore. This might sound like a silly fix, but it's actually one of the most common mistakes made by people using this(and other automatic buttonholing) machine.
Re your buttonhole foot - please note the following:
- This foot comes with a metal underplate.
- Place the fabric between the foot and the underplate.
- I am assuming that you have the buttonhole lever pulled down.
-Note: The silver coloured buttonhole lever is directly behind the needle threader. Pull it all the way down.
-When u have all the above in place, start the buttonhole. When it finishes the first side, gently push the foot back, so it reverses. I know this sounds strange, but if you have slightly bent the underplate you will need to do this.
- The directions are in the manual on page 60.
