Question about Cuisinart SS-700 5-Cup Coffee Maker
Ss-700 keeps flashin Not Ready
I made a cup of coffee. then steped outside. when i came in the ss-700 pump was running and the display was flashing Not Ready. i unpluged and pluged back in. now it constantly flashed Not Ready... Any idea? i've been reading a lot and cannot find this problem referenced.
Posted by Mike Mazzola on
  • Don Slade Aug 18, 2012
    The coffee maker power up with default settings so I did have to reset the clock and the preferred cup size, etc.
  • M ford
    M ford Dec 02, 2017
    THANKS MAN I JUST USED IT TO GET MINE WORKING AGAIN !
Don Slade
    New Friend:
I had the flashing not ready problem with my SS-700 Cuisinart as well. I pressed and held the rinse and Hot Water buttons at the same time for about 10 seconds while the Not Ready was flashing. After 10 sec or so the display went off completely. I then powered up with the power switch on the side and the coffee maker came and is working fine so far.
Posted on Aug 18, 2012
  • 11 more comments
  • kimberly_300
    kimberly_300 Oct 31, 2012
    this worked for mines thanks!
  • clintlajeune
    clintlajeune Nov 28, 2012
    ya thanks bud. thought i was throwing it out. now working again.
  • lyndiem15
    lyndiem15 Dec 07, 2012
    mine did the same thing, was starting to panic! Why did it do this? Thanks!!
  • Jenn Burn
    Jenn Burn Oct 25, 2013
    omg..you guys just saved me!!! thanks so much for the help! Don, you rock! :D
  • Cyndi
    Cyndi Dec 16, 2013
    Thank You for posting this .. I thought I Broke my new machine.. whew .. I was panicing
  • pattonlawfir
    pattonlawfir Jan 25, 2014
    It's official. Don is the man. Worked like a charm.
  • Felicia Tucker
    Felicia Tucker Sep 25, 2014
    Don is the man!!!! Wow worked like a charm!!! Thanks!!!
  • Sally Smith
    Sally Smith Feb 03, 2015
    Jeeze! you're great. don't ya just LOVE the internet!! I was about to throw the dang thing away.
  • Mark Orr
    Mark Orr Mar 13, 2015
    THANK YOU!!! This worked! Cuisinart Customer Support was 100% useless. I too was about to throw mine away because it was out of warranty. You saved me $199. Again - thanks.
  • Nick S
    Nick S Mar 20, 2015
    I had two SS 700's with the same problem. The first was replaced under warranty in 2012. The second was out of warranty when it failed in 2015. I purchased another from Cuisinart at a discount. I then searched the web for a solution to keep the machine as a backup. I stumbled onto the button holding solution by experimentation. I found a site that suggested holding the on-off switch while plugging in the unit on a B60 model with a similar problem. I think I "confused" the logic board by pushing the buttons too fast. I think the unit "locked up" and needed a reboot :)
  • Chad Martin
    Chad Martin Nov 21, 2016
    This is THE Solution.
  • Lisa Graham
    Lisa Graham Oct 23, 2018
    Thank you, Thank you, Thank you!
    I was on hold with Cuisinart for over 40 min when I found this answer and my machine was up and running in 3 seconds!
  • Robin Olivarez
    Robin Olivarez May 02, 2019
    Thank you so much!! 2019 and this is stil the solution!
Connie Hunter
    New Friend:
  • 12 Answers
Get a Bunn
Posted on Oct 23, 2018
5 Related Answers
Anonymous
SOURCE: keeps flashing 12:00
I just kept plugging and unplugging the coffee pot. Eventually, the clock stopped blinking, the buttons worked, and all was well.
Posted on Jul 20, 2008
Anonymous
  • 61 Answers
SOURCE: DCC-1200 coffeemaker cleaning button flashes
Make sure that when you do the vinegar solution, you do at least 4 cups of white vinegar, and fill it up the rest of the way (max fill line) with water. The manual says to "fill to capacity with a mixture of 1/3 vinegar and 2/3 water," which lots of people misunderstand, and think it means "1/3 CUP vinegar and 2/3 CUP water," which is not the case. It means 1/3 of your 12 cups (and 1/3 times 12 is 4 cups) of vinegar, and 2/3 of your 12 cups (aka, fill it up the rest of the way) of water.
You might have to let it soak for an hour before you try to brew it--this lets the vinegar work at the calcium buildup a LOT better (kind of like soaking your pots and pans before you try to clean them), but it should definitely work for you. If not, call Cuisinart's tech support (1 800 726 0190) and they might be able to get you a replacement :)
Posted on Aug 21, 2009
Anonymous
SOURCE: Coffee maker is extremely slow with lots of steam.
Im having same problem with my m/n CBC00. Suspect clogged orifice or bad oring where tube swivels under lid. But I cant get it apart without security scewdriver wich is on order. Ill tell more when i find out.
Posted on Feb 01, 2011
mc1bean
Mike Cairns
  • 3053 Answers
SOURCE: SS 700 takes 95 sec
Hello, rick
I was trying to help you out here. Maybe this will help some? I was going backto some customers that asked questions in the recent past and even fartherback. It appeared that no one answeredsome of them, So, I thought I would take some of my personal time to see if Ican help. Even though this Informational site may not have your exact model orbrand, this site will help you a lot. Here is a site link about everything you want to know about CoffeeMakers and possibly yours, from
repair to trouble shooting it. b>http://home.howstuffworks.com/coffee-maker4.htm
Please if this helped you at all, if you can find the time and in your heart torate my help and some kind words written would be appreciated for my free help, I would appreciate it.
Here is also my direct link to my own pages of other areas of my expertise forother problems you might have in Automotive, Appliance, and Electronics. DropIn anytime for my help.
Thanks, Mike
http://beta.fixya.com/users/mc1bean
Posted on Oct 29, 2011
Anonymous
SOURCE: The cleaning button keeps flashing after cleaning.
We have this problem as well. We simply clean it as directed once or twice with the vinegar and water mix and then unplug for an hour. This resets our machine for several weeks. Based on the number of comments I've seen on this issue, it seems that the "off" sensor doesn't work.
Posted on Oct 13, 2009
How can i empty the inner tank of a cuisinart ss 700 fr
Hi, Susan
I don't have your model but I'm going to guess that you should remove the external reservoir and run the machine as if you were making tea or coffee.
Mar 22, 2014 | Cuisinart SS-700 5-Cup Coffee Maker
Not filling up cup
I got a Cusinart ss-700 that was tossed out. I'm finding that most of the malfunctions that people have been complaining about are definitely circuitboard-related. When you get errors and pump failures, etc., as with a computer (or any device with a programable board), unplug completely to clear all memory chips and reset the programing. Plug it back in and turn it on, and you'll get back all of the menu items and water will pass through the pump, into your mug. The problem I'm seeing is that it still doesn't pump the right amount of water. For a six ounce (default) brew/hot water, I'll get 3 ounces, then after a reboot, it gives 2 more ounces - another reboot and it gives another 2 ounces. Definitely a bad batch of motherboards in these ss-700's. I hope the guy that scored that manufacturing/supply "deal" got a demotion! Also notice that there's no reply/remedy from Cusinart - obvious that it's water under the bridge. :(
Jan 30, 2014 | Cuisinart SS-700 5-Cup Coffee Maker
When brewing it makes a loud noise
I have 2 Cuisinart Coffee makers. Both make loud humming noises during the pump cycle. In my units, the water reservoir vibrates when the pump is active. Test by hand pressure on the water reservoir when brewing.
I experimented with adhesive foam pads and they worked well but...they eventually fell off. I often just push the unit against the wall behind it.
Oct 14, 2013 | Cuisinart SS-700 5-Cup Coffee Maker
My cuisinart keurig ss 700 wont turn on
sounds crazy but check switch on side of machine if you have already srry wild shot in the dark (some people dont see extra buttons and switches even though they are good w electronics) took me an hour to realize i had one in plain view and i repair cell phones all day
Nov 28, 2012 | Cuisinart SS-700 5-Cup Coffee Maker
Light never stops flashing in my 36 cup farberware urn...what could be the problem/
Light tells you the coffee is ready and will stay on un till you unplug it. Ron. PS don't mind the flashing, some do and some don't.
Sep 28, 2012 | Faberware 12-55 Cup Coffee Urn
Need instruction book for Cuisinart Single Serve Brewing System Model # CUISS-700
Here are the instructions to de-scale your Cuisinart SS-700, taken directly from the unit's manual, available here (www.cuisinart.com/share/pdf/manuals/ss-700.pdf):
1. Empty the reservoir.
2. Disable the AUTO OFF and OFF TIME features.
3. Making sure there is no K-Cup in the brewing chamber, fill the reservoir with 60 oz. of undiluted white vinegar.
4. Place a large mug on the drip tray and run a Hot Water cycle. Select the 12 oz. brew size. Discard contents of mug.
5. Repeat the hot water process until ADD WATER is displayed on the control panel and the reservoir lights will flash.
6. Let the Brewer stand for at least four hours while still on.
7. Rinse the water reservoir thoroughly and fill with fresh water.
8. Run another Hot Water cycle. Discard contents of large mug.
9. Repeat hot water process until ADD WATER is displayed on the control panel and the reservoir lights will flash.
10. You may need to perform additional Hot Water cycles if you detect any residual vinegar taste.
Note: If DE-SCALE is still displayed on the control panel after completing the procedure, repeat the de-scaling procedure above.
If you found this solution helpful, please leave a positive rating!
Sep 17, 2012 | Cuisinart SS700 SINGLE SERVE BREWING...
Leaking underneath
You are not alone having the water leak in your SS-700. For better understanding what caused that leak please read the review on Cuisinart SS-700:
http://www.cuisinartfoodprocessordeals.com/cuisinart-ss-700/
Nov 22, 2011 | Cuisinart SS-700 5-Cup Coffee Maker
Cuisinart ss-700 open head message stays on...
I have the same problem and wonder how to fix it
Feb 03, 2011 | Cuisinart SS-700 5-Cup Coffee Maker
Cuisinart SS-700 5-Cup Coffee Maker Logo
6,572 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
ThaMp3Doctor
ThaMp3Doctor
Charles Tidwell
Marvin
Marvin
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
