Question about Dogs
Should I give my dog pigs ears? - Dogs
Posted by D. Lover on
Anonymous
I have read a lot of forums about this and it seems as though they are not that popular among dog owners. A lot of them say that the pigs' ears make their dogs sick with loose stools and others say that their vets have told them that pigs' ears are crawling with bacteria. So I wouldn't advise you to give them. Check out this forum: http://www.dogforums.com/dog-food-forum/951-pigs-ears-bad.html
Posted on May 13, 2012
Can I give my dog an antibiotic that was prescribed to me to treat his ear infection
Some human medications can be used by dogs but not all of them, if you love your animal, you should consult a vet and ask if the medication will not make your dog sick or worst.
Nov 04, 2014 | Dogs
Can pig ears be dangerous for dogs?
Yes, they can. The problem with pig ears is that once the dog chews on them, they can break into small pieces, which then can be dangerous for the dog if it eats them.
Aug 23, 2012 | Baby Einstein Dogs
What can I do to help prevent my dog from getting an ear infection? I clean his ears regularly; however he still seems to be getting infections.
I found a great natural remedy that works in preventing ear infections in dogs. I use it for my dogs and they have been ok for almost a year now.
THE FOLLOWING ALL NATURAL REMEDY
PREVENTS EAR INFECTIONS! This recipe is not meant to be used with Zymox. This should only be used once the ears are completely healed.
Keep in mind that it "will not" cure an existing ear infection.
Once you get your dog's ears to a healthy state either by using Zymox like we recommended or with the help of an antibiotic from your veterinarian, start using the following remedy weekly to prevent future infections. This works by raising the Ph level in the dogs ears.
Purchase an eye dropper bottle and the following ingredients
from your local pharmacy.
2 Tablespoons of Boric Acid
4 ounces of Rubbing Alcohol
1 Tablespoon of Glycerine
Shake the bottle before each use to thoroughly mix. Place a small eyedropper full into each ear. Cup the dog's ear and massage gently. Allow the dog to shake his head and gently blot dry any excess on the outside of the ear.
Do this weekly.
If ANY IRRITATION occurs - STOP using the recipe immediately!
Aug 15, 2012 | Pets - Others
In regards to pet grooming, what does the term puppy cut refer to?
When someone tells a groomer they want to give their dog a puppy cut they mean that they want their dog to look like it did when it was a puppy.
How do I properly give my dog a bath?
Before getting wet, brush your dogs fur to remove all knots and dead hair. Next put your dog in a tub filled with a few inches of lukewarm water and use a pitcher or large jug to get your dog wet allover. Now you will need to massage in shampoo, I recommend starting at their head and working your way down to the tail. Then you can rinse the shampoo away. Be careful around your dogs ears, eyes and nose. Finish by drying your dog off with a towel.
Are pig ears a healthy treat?
Although they are quite delicious for dogs, pig ears contain a lot of fat. So if your dog suffers from obesity, do not give it pig ears.
Aug 13, 2012 | Dogs
Dog ear in the outfeed
You do not state model so I will give you a general tip. Dog ear pages are mostly caused by something in the paper path dragging on the paper. This can be a piece of label stuck in printer, torn bit of paper or toner built up on the fuser. Check the area where the paper comes out of the paper tray closely because this is where problems often start.
Apr 04, 2011 | Office Equipment & Supplies
Need to get the agitator off
that's funny [feed dogs]they are called, dog ears but you do now have to feed the dogs because their not working.lol.hey you will have to get those parts on-line or at an appliance store.lowes wont carry those that i know.anyway if you pop the cap of the agitator you will see a piece that has a small handle.pull up and remove that piece.then you will see the bolt to remove to pull the agaitator[its a 7/16]take a good look at how its together before you take apart.......ok now that the agitator is out place on floor,put feet on the bottom piece and pull up on the top piece til comes off.then dump out the piece in the top w/dog ears in it........install new ears in that piece and reinstall upside down,inthe top piece of the agitator.then apply pressure on the dog ear retainer and place over the bottom piece of the agitate aligning the two little tabs sticking up on the bottom piece of the agitator with the little cut outs in the dog ear retainer....now take your socket to place bolt back on,put some plastic wrapper or package from dogs in the socket and push the bolt into it.then place the bolt in the hole of the dog ear retainer .now lift agitator up and place onto transmission shaft and tighten bolt and place cover back on................boy that was a lot of words.that should do it for you God bless you Tiffany ,from tom
Jan 24, 2009 | GE WBSR3140DW Top Load Washer
Dogs Logo
362 people viewed this question
Top Dogs Experts
Thomas Perkins
Thomas Perkins
Rhonda Webster
Rhonda Webster
Tom Chichester
Are you a Dog Expert? Answer questions, earn points and help others
