If those files weren't premarked properly on computer before synchronizating (you can do that in WMP 10 with advanced tag editor) it's not likely you'll get those results. You can add those info on computer and sync files again.
However, if all of these files are marked properly (have filled Artist, Title and Album sections in advanced tag editor) maybe database is corrupted - what you need to do is refresh it. (Settings>Extra>DataBase Refresh>Yes)
SOURCE: iriver H10 20GB - i can't access my music through Artists or Albums
Have you tired doing a "Database Refresh". It's located on the main screen under "Settings". Go to Database Refresh and check "Yes". How much music you have on your player will determine how long the refresh will take. If that doesn't work possibly run the Firmware Updater from iRivers' web site and only update the database, do not do a complete "Recovery" or all of your music will be erased as that choice reformats your hard drive. Only choose "Update Firmware"
Regards,
John H.
SOURCE: Half of my music artists list is gone.
well your computer obviously has wiped it and doesnt have the artists there any more
SOURCE: When I press
it's because the iriver doesn't reconize the artist. the artist name, album etc is set in the file's info. you can write that info yourself so the iriver can reconize it. for example I opened Winamp, imported the songs I wanted in my iriver, right clicked on the the first songin my list, selected FILE INFO and went on and completed the artist field myself. did the same to every other song....and now the iriver reconizez the artists.....it takes some time indeed...and I don't know of any other easyer method that works.....but this one surely will. good luck :)
SOURCE: Just bought an IRiver E150 8gb. Loaded my music on
Yo Man it may just mean they are the wrong file type. Check what file types are compatible with the device and then convert them. The best way of converting a file type is FormatFactory. GOOD LUCK XD
