Question about NetGear WNDR3400 N600 Wireless Dual Band Router (WNDR3400100NAS)
Can't log into WNDR3400 Router GUI not through 192. or reouterlogin
I have been trying to log into the router through http://www.routerlogin.net and through http://192.168.0.1 or .1.1 and .2.1 (my gateway), but neither works. The routerlogin redirects to Netgear's support site.
  • NetGear Master
  • 7,733 Answers
192.168.1.1
Posted on May 07, 2015
1 Related Answer
Anonymous
  • 5 Answers
SOURCE: I did a reset to
Go to http://192.168.0.1 or http://192.168.1.1 rather than routerlogin.net.
Posted on Feb 28, 2011
I just bought a wireless router netgear N600 and I have problems trying to connect it to my samsung tv (using a samsung lan adaptor model WIS09ABGN) On the TV screen you can see the network, but when I...
Well it seems to be an issue with the security setup on the wireless router. Please perform the below task to configure the settings on the router:
1. Open a web browser (Internet Explorer, Mozilla Firefox or Safari) on a computer connected to the router.
2. Access the router's GUI by typing 'http://192.168.1.1' or 'http://www.routerlogin.com' in the address bar.
3. When prompted for Username and Password, please enter 'admin' for the Username and 'password' for Password.
4. Click on Wireless Settings'(under Setup) from the left menu.
5. Select security options as 'WEP (Wired Equivalent Privacy)'. Set the 'Authentication Type' as automatic. Set the 'Encryption Strength' as 64-bit.
6. In Key 1 type a 10 digit number. Apply the settings.
Please connect your TV to the network using the password as set above.
Regards
Anand
Oct 26, 2011 | NetGear WNDR3400 N600 Wireless Dual Band...
I can not get internet access to my router, I have internet access but only by directly connecting my desktop to the modem. The modem will not send internet access to my new router.
I understand that you are not able to go online through the router WNDR3400. Please perform the below task to reset and reconfigure the router:
RESET:
With the help of a paper clip, press the reset button on the back of the router for 20 seconds (please refer to the label on the bottom of the router for reset button location). Release the reset button after 20 seconds and turn off the router. Turn the router on after few seconds.
CONNECTIONS:
1. Connect an Ethernet cable from the modem to the WAN port of the router (isolated port).
2. Connect the computer to the router using any one of the 4 available ports. Please make sure that there is no direct connection between the modem and the computer (either using Ethernet cable or USB cable).
3. Power off the modem and the router after making the connections.
4. Power on the modem and wait for the lights to come on and then power on the router.
RECONFIGURE:
1. Open a web browser like Internet Explorer, Mozilla Firefox or Safari.
2. Access the router's GUI by typing http://192.168.1.1 or http://www.routerlogin.com.
4. Click on 'Basic settings' from the left menu and select 'Use Computers MAC Address' from 'router MAC Address' section.
5. Click Apply.
6. Once it updates the settings then power off the modem and the router. Power on the modem and wait for the lights, then power on the router.
Please revert back for any further clarification.
Regards
Anand
Oct 03, 2011 | NetGear WNDR3400 N600 Wireless Dual Band...
I pressed the reset button on my router WNDR3400 now i dont have any internet acess. help please
Your wireless router has reset back to default settings. You need to access the GUI of your router to retrieve your wireless info. Connect 1 PC to the router using an ethernet cable. Once you have internet access, open your browser and type in on the address bar 192.168.1.1 to access the GUI. If it doesn't work, try http://www.routerlogin.net. Use "admin" for the username and "password" for the password. Once your logged in, go to the wireless settings and check for the details of your wireless connection.
Sep 04, 2011 | NetGear WNDR3400 N600 Wireless Dual Band...
Forgot username & password for netrouter wgr614v7
How do I log into my router?
To log into a NETGEAR router:
  1. In your Web browser, navigate to the router login page. By default, one or all of the following URLs should work:
    • http://www.routerlogin.net or http://www.routerlogin.com
    • http://192.168.1.1 or http://192.168.0.1
    Note: You can sometimes find the login URL on a sticker on the bottom or back of the router.
  2. Enter the username (admin) and the password.
    • The default password is password, or for older routers, 1234.
    • If you have already changed the default password, use the password you assigned the router. Passwords are case sensitive.
    • If you have already changed the password and do not remember it, you have to reset the router to factory defaults in order to use the default password. Resetting a router to factory defaults erases all changes you have made to the router's configuration files.
This information is extracted from www.netgear.com, for learning purpose only.
Hope this will be useful for your question.
Good luck. Remember to rate my answer please.
Jul 13, 2011 | Computers & Internet
My wireless router (NetGear N600 Dual Band Router, or WNDR3400) keeps dropping randomly and will have to reconnect and it always takes several minutes.
Well, I would recommend you to update the firmware on the router using the below steps:
A. Open the router page using the following way:
1. Connect a computer to the router using any one of the 4 available ports.
2. Open a web browser like Internet Explorer, Mozilla Firefox or Safari.
3. Access the router's GUI by typing 'http://192.168.1.1' or 'http://www.routerlogin.com' in the address bar.
4. When prompted for Username and Password, please enter 'admin' for the Username and 'password' for Password.
B. Visit the following link to download the latest firmware.
http://kb.netgear.com/app/answers/detail/a_id/17216
C. Please follow the steps to upload the firmware of the router:
1. Open the router page using the steps mentioned above.
2. Under Maintenance, click router Upgrade.
3. Click Browse and locate the upgrade file.
4. Click Upload.
5. Wait for the router to reboot.
6. Click on 'Logout' (at the bottom of the list) from left menu.
Please revert for any further clarification.
Regards
Anand
Apr 21, 2011 | NetGear WNDR3400 N600 Wireless Dual Band...
Router stopped recieving an internet connection all of a sudden. all cables are connected as befour ,
Perhaps try logging into the GUI by opening a web browser and typing in "www.routerlogin.net" - - us admin/password to log in and manage the device. In there you can find the status of the router to give you more information. Otherwise try resetting the device and/or upgrading the firmware.
Feb 22, 2011 | NetGear WNR2000 Wireless Router
I need a download for the installation. I do not have my cd. I cant use it without it.
Log in to your NETGEAR router by browsing to http://www.routerlogin.net or http://www.routerlogin.com
i have noLog in to your NETGEAR router by browsing to http://www.routerlogin.net or http://www.routerlogin.comt tried this its only a possibility that might help
or
Free Phone Support for NETGEAR Warrantied Products
For products purchased new in the last 90 days in the USA and North America:
1-888-NETGEAR ' 24 hours/day, 7 days/week
For products purchased new in the last 90 days outside of the USA:
Phone Numbers by Country ' Support hours vary by country
For products purchased more than 90 days ago, please review the
Scope of NETGEAR's Free Technical Support
To register your product or determine if your product is still under warranty, go to http://www.netgear.com/register
Jan 23, 2011 | NetGear WGR614 Wireless Router
We cannot log on with the assigned password
Log in to your NETGEAR router by browsing to http://www.routerlogin.net or http://www.routerlogin.com. Enter the username (admin)and password by default the password is 1234 unless it has already been changed
from the left-hand navigation menu of the router manager,select wireles set up>wireless settings
from the center screen,select your encrytion type from under the Security Options heading
if the wireless network passphrase is visible,review it and use it to log on devices onto your network.
If it is not visible you can change your wireless passphrase but changing your passphrase will cause you to lose your wireless connection
Connect your computer to the router using an Ethernet Cable before entering a new passphrase into the text box and clicking apply.
If you cannot log into your router:Unfortunately, there is no way to recover a lost or forgotten password from a router or access point; you will need to reset the device to factory defaults. However, once the device is reset to factory defaults, you can use the default username ("admin") and password (either "password" or "1234" depending on your router) to reconfigure your router settings.
Restoring factory defaults on a device will erase any customizations you have made. You will lose any configurations saved to the device!
From the center screen, select your encryption type from under the Security Options heading.
If the wireless network passphrase is visible, review it and use it to log devices onto your network.
If it is not visible, you can change your wireless passphrase; however, changing the passphrase will cause you to lose your wireless connection. Connect your computer to the router with an Ethernet cable before entering a new passphrase into the text box and clicking Apply.
hope this helps
Dec 30, 2010 | NetGear WNDR3400 N600 Wireless Dual Band...
How do i get the password
Type http://www.routerlogin.net in the address field of Internet Explorer.
When prompted, enter admin for the router user name and password for the router password,
both in lower case letters.
If it does not log you in, then there is a different user name and password on the router.
To reset that, you can restore these defaults with the Factory Default Restore button on the rear panel. Hold the button down for 15 secs then release. Wait 1 minute, then try log in to the router using http://www.routerlogin.net in your browser and don't forget to set a password. Hope that helps.
Nov 09, 2009 | NetGear WGR614 Wireless Router
NetGear WNDR3400 N600 Wireless Dual Band Router (WNDR3400100NAS) Logo
346 people viewed this question
Top NetGear Computers & Internet Experts
Mike
efs_perpends
efs_perpends
Lee Hodgson
Lee Hodgson
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
