Question about Connex CX-3400hp AM/FM 10 Meter Amateur Mobile Transceiver
Fix my connex 3400 hb sideband button
Sideband button does not work
Posted by sdbjr on
stratomas59
    New Friend:
  • 3 Answers
Hi there, if you are talking about the Connex CX 3400 HP there is no sideband or SSB on this radio. It is only AM and FM 10 meter Ham radio. Many people do modify these radios to include the 11 meter frequencies which is the CB band. Maybe knowing the actual bands and their frequencies will help some too this radio does have 6 different bands ranging from (Band A. 28.015 thru 28.455) (Band B. 28.145 thru 28.585) (Band C. 28.115 thru 28.555) (Band D. 28.085 thru 28.525) (Band E. 28.055 thru 28.495) (Band F. 28.025 thru 28.465.) I hope this will help you. Bob
Posted on Dec 09, 2012
Single side band
Sideband transmission will cause the meter to swing as you speak.
Jan 28, 2014 | Radio Communications
My cobra 148gtl has low modulation on sideband. What can I do to correct this.
Check the Mic. Sideband you can talk up. ie the louder you are the more mod.
Jan 24, 2014 | Cobra 148GTL AM/Single Sideband CB Radio -...
I HAVE A GRANT LT WORKS FINE ON AM NEEDLE NEVER MOVES WHEN YOU KEY UP ON SIDEBAND
Beware that there is no carrier or deadkey on sideband. So there will be no meter movement until you add audio.
Nov 28, 2011 | Uniden GRANTLT 40-Channels Base CB Radio
How to use ssb usb am cb radio
  • Well, AM is Amplitude Modulation and Sideband suppresses the carrier and uses only the top half (upper sideband) or lower half (lower sideband) of the wave.
  • Whether using AM, USB or LSB you are on the same frequency although if someone is on USB and you are on LSB you will not be able to understand what the other person is saying because you are using different parts of the wave. So 27.185 (channel 19) on AM, USB or LSB is still 27.185.
  • If you have further questions please let me know.
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Regards,
Tony
Oct 01, 2011 | Galaxy Radios DX-959 40-Channels Base CB...
The galaxy radio is a 2980 and the RF power does not work how do u fix it or were on the board can I fix it
are you talking about the variable rf knob or do you not have rf power output? check it to a radio next to you with no antenna on the checking radio. and see if it will move the meter.. if it does they change the rf final transistor..
Dec 21, 2010 | Galaxy Radios DX-2517 CB Radio
I have an HR 2510 that shows no dead key watts on AM ????
This sounds exactly backwards, you should have a carrier on AM with some forward swing, on SSB (sideband) there should be no carrier & all modulation (forward swing). Could you have the settings mixed up or has somebody put a modulation kit in your radio & messed something up or maybe one of the knobs has been removed & not replaced correctly ? Just a couple of things you might look into.
Jun 19, 2009 | Superstar Radio Communications
Sideband carrier??
im not sure carriers are measured in pounds, but SSB is a supressed carrier mode, in SSB only one sideband is transmitted and the carrier is inserted at the other end in the receiver. In AM mode the carried and both sidebands are transmitted. with regular am there is a carried and when modulation (your voice) is added a signal appears both above and below the carrier frequency at a distance relative to the frequency of your voice. so if you have a carrier at 1000 khz and modulated it with a tone of 100 hertz the signal will contain frequencies of 900,1000, and 1100 hertz, then its changed to SSB by supressing the carrier (1000) and one sideband (1100) if you are on lower sideband and (900) if you one upper sideband, and transmits the remaining frequency.
Nov 06, 2008 | Ranger RCI-2995DX Base Scanner
Connex 3300 hp
U mean on sideband? Frequency counter only useful on other than sideband operation. This does not mean the carrier insertion osc. is on frequency. If it needs adjustment, your voice will sound high/ low on transmit. Incoming signals will sound right after adjusting the osc.
May 14, 2008 | Connex 3300 240-Channels Base CB Radio
Switching radio bands
what radio do you have? does it even have sideband channels? some radios don't come with them, of fm or upper or lower side bands and short wave
Dec 08, 2007 | Connex 3300 240-Channels Base CB Radio
Connex CX-3400hp AM/FM 10 Meter Amateur Mobile Transceiver Logo
188 people viewed this question
Top Connex Radio Communications Experts
Tony Raia
Marvin
Marvin
Are you a Connex Radio Communication Expert? Answer questions, earn points and help others
