Stereo radio unlock code
SOURCE: radio
Most radios with security codes come up when the battery is disconected or goes flat. In t your sevice book there should be a code that you put in using the numbers on the radio.
SOURCE: Car Stereo Code??
the code is a user code that someone had enter at an earlier date and when the radio loses power it goes into security mode, thats what you have right now. The only way to get this code is you have to call infinity tech services and a tech will walk you through the steps in reseting the code
SOURCE: I need a car stereo color coded wiring guide mitsubishi galant ES
They are very easy to find online. Just google wiring diagram for the make and model.
SOURCE: I hae a 2002 mitsubishi lancer I need wiring
Here is a link that should help you get the wiring colors you asked for. Good luck and hope this helps. http://www.installdr.com/Harnesses/Mitsubishi-Wiring.pdf
isn't there a way without taking the stereo out? :'(
