Question about Rockford Fosgate Punch 500a2 Car Audio Amplifier
SOURCE: not a problem just a question
Wire your sub in bridged mode (4 ohm mono)
+ to + on amplifier
- to - on amplifier
(using bridging terminals)
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Posted on Apr 25, 2009
SOURCE: Rockford fosgate 800 a2 amp power?
Hello desperate2le,
Watts delivered is a function of the voltage times the current. If the amp was 100 percent efficient, it would need 33 amps at 12V for 400 watts. At 14.4V, it would only need 28 amps. Of course, amplifiers are NOT 100 percent efficient, only about 50-60 percent in many cases, but somewhat higher for monoblocks, maybe 80-90 percent. So you're looking at a fuse in the 60-80A range. In the absense of a specific fuse size from the manufacturer, I'd start the primary fuse at a 60A and if the amp blows it on power up/immediately/frequently, move up to an 80A.
All of the Rockford-Fosgate 2-channel bridgeables I've ever seen show using the left positive (+) and the right negative (-) for bridging. But if it's not shown right on the amp, I'd call or email RF for the correct connection. The new amps do show it.
Hope this helps.
Posted on Apr 28, 2009
SOURCE: Rockford Fosgate Punch 800 A2 shorting out.
replace the inputs on ur amp
Posted on Jun 29, 2009
SOURCE: rockford fosgate 450.4. 1st protect mode, now blows fuses...
smell it !
Posted on Oct 13, 2009
SOURCE: Rockford Fosgate Punch End CapsEnd Caps
I TAKE IT THAT YOU ARE REQUESTING A SOURCE FOR A PAIR OF ENDCAPS FOR YOUR PUNCH-200IX. IF THIS IS THE CASE, I SUGGEST THAT YOU CHECK EBAY ON A WEEKLY BASIS AS I AM SURE AFTER SOME TIME, YOU WILL SEE A PAIR LISTED. THERE IS ALSO A SELLER ON EBAY THAT HAS MANY OF THE LOGOS FOR THE MANY DIFFERENT MODELS THAT CAN BE PLACED ON ANY OTHER MODEL ENDCAPS FROM THE SAME SERIES (DSM, IX, X2, ETC. LET ME KNOW IF I MISUNDERSTOOD YOUR REQUEST......V
Posted on Jan 06, 2010
