Downloaded firmware now the blueray player wont turn on
Unplug player from wall receptical and unhook the remaining attachments, press and hold power for at least 2 minutes to reset the processor, if this fails, go to www.panasonic.com contact customer support and the technical department.
SOURCE: can't get Blueray player to release DVD
You may now have corrupted firmware. did the dvd contain the firmware update?
Are you sure there wasn't already a cd in the tray? (Ie two cd's are now inside?
The easiest way to remove the cd if turning off fails is to remove the screws around the casing. Lift off the lid and the cd should come out easily, however if the update was corrupt or the wrong firmware you may now have a dead player.
Try removing the Cd as described first with the power off and plug removed.
Then see if the unit powers up and the drawer opens.
If so you may be able to revert it to its original firmware from the vendors site.
Regards
Marc
SOURCE: update BD/DVD player
I went back to the store that I purchase the dvd player. Thank you, Ken
SOURCE: my panasonic dmpbd10a blueray player wont play
With people downloading movies illegally, companies have put blocks on DVD's, unfortunately making the DVD unplayable for some blue-ray players
http://www.njnnetwork.com/2010/04/avatar-blu-ray-wont-play-on-all-players/
Latest firmware is..
HTB-C6930WWB-1016.2.zip
This can be downloaded (with instructions) at http://www.samsung.com/uk/support/detail/supportPrdDetail.do?menu=SIA00201&prd_ia_cd=802&prd_mdl_cd=HT-C6930W%2FXEU&prd_mdl_name=HT-C6930W%2FXEU&srchword=HT-C6930+3D+Blu-ray+5.1+Home+Entertainment+System
If you already have this firmware then you need to contact Samsung.. The last upgrade was 5th oct 2012.. not good enough Samsung.. :(
