How do I use thread that is on a serger cone for my Kenmore 385.19365? Can I re-wind it onto a regular spool? If so, are there secrets to keeping a filament thread winding properly? Since the large cone would not fit on my normal bobbin-winding spool pin, how/where could this be done? I would guess I would have to hold it and do it VERY slowly. Advice, please
SOURCE: sewing machine-yamata-900
http://pcmonkey.co.uk/jsm-download.com/manuals/English%20Maunals/pf2100%20english.pdf
found this in another post....link is to a downloadable users manual.
Hope this helps!
~enov8
SOURCE: start/stop button is not working.
When you have the embroidery unit connected to the machine, you must have the foot pedal cord disconnected. Then it should work. As for using this machine for normal sewing, yes, it is supposed to do that. Unless you get a lemon like mine. It lost reverse, and only takes long stitches. Hopefully your luck is better than mine with this Disney "thing".
SOURCE: Jammed spool pin on a Brother CE5000 PRW sewing machine
Try a little oil and let it set befor pulling.
Testimonial: "Awesome solution- thanks so much!"
