Question about HP OfficeJet 6210 All-In-One InkJet Printer
Outgoing Fax on my HP Officejet 6210 All-In-One
I installed a new BellPhones 5.8 to my 6210/cable/internet system. I am unable to send out any faxes - each number just keeps ringing and ringing. Can you help me? I've tried every type of set-up I can think of. Everything works except the outgoing fax (I have no incoming fax number).
BA
Posted by Barbara Asher on
Bart Walker
    Novelist:
  • 206 Answers
I would take the phone line that goes into your Officejet 6210 and plug it into a normal telephone. Dial the fax number manually and see if a fax machine picks up on the other end. If you can't get a fax machine to answer even when you are manual dialing, you are calling phone number that has no fax machine connected. In other words, you are calling either a bad number or there is a pool of fax machines and they are all too busy to pick up your call. You can redial try the number repeatedly to see if you can get through in that case.
Posted on Jan 23, 2018
Lawrence Oravetz
  • HP Master
  • 10,548 Answers
The fax machine needs to hear a dial tone first to send a fax. If you have no fax number, what working phone number are you using?
5 Related Answers
Anonymous
  • 58 Answers
SOURCE: Cannot receive fax but everything else works
Is the fax receiving setting set to "auto" or "manual" receive?
Posted on Jul 07, 2007
Anonymous
  • 99 Answers
SOURCE: HP laserjet 1020 fax incoming fax, machine
hp laserjet is not a fax.It is only a printer.
Posted on Dec 09, 2009
Everett Lin
  • 990 Answers
SOURCE: officejet 6310 fax does not work
Hello sir; would you take one phone hook up with this phone jack,if there have dial tone,that's means fax modern defective, if no dial tone that's means this phone jack is not active.
Posted on Jan 27, 2010
Walid M Sayed
  • 313 Answers
SOURCE: printing, copying, incomming fax is ok but
it may be the fax bulb is burned out
Posted on Mar 16, 2010
puertobori
  • 7733 Answers
SOURCE: HP Officejet J4580 All-in-One -
Using the HP Network Diagnostic Utility in Windows - HP Customer Care (United States - English).
or Try using the HP Print Diagnostic Utility in Windows - HP Customer Care (United States - English)
If you need more help come back.Post / thumbs / testimonial are welcome!
Posted on Nov 24, 2010
Will the HP 6210 work with VOIP and Win 7?
HP Officejet 6210 All-in-One is not tested on VOIP connections when it was in manufactured. However these printers do work with VOIP connection.
If you are unable to get the printer working on VOIP connection, there are few ways to fix this.
1. Reduce the Fax speed of printer ( from Setup - Basic Fax Settings - Fax Speed ). Try to Fax
If this does not work, try the step below
2. VOIP is Digital technology and HP 6210 works on Analog Signals ( standard telephone line )
- You need a DSL Filter which converts the Digital Signals to Analog and vice versa. This filter is available at any departmental store or computer accessory shop
- Connect the DSL Filter to phone socket. Connect the printer telephone cable to Analog port of DSL Filter ( to Line 1 Extn port of printer )
Either of this should fix the solution. However there is another solution which may or may not be possible. It is to reduce the baud rate on your Cable connection ( though not recommended )
Regards,
Shawn
Jan 28, 2011 | HP OfficeJet 6210 All-In-One InkJet...
I want to know how i can use my copy machine to a fax so i can use it for incoming or outgoing?
Install software
Make sure all cables plugged: phone cable, USB cable to computer
Send fax from computer:
- print your document to printer HP .... FAX
Send "traditional" fax:
- put your document into scanner input
- type phone number on HP Officejet keyboard
- push button "Send"
If your HP Officejet if connected to phone line, it reseiving faxes automatically.
Hope this helps
Nov 12, 2010 | HP Officejet 4215v All-in-One Printer
I want to conect my hp officejet6210 all in one printer and fax machina
This step-by-step guide describers how to obtain and install HP Officejet 6210/6213/6215 All-in-One Basic Software/Driver 4.7.0 Windows 98/ME/2000/XP drivers for Windows.
1. Define your HP Multifunction device model.
2. Define your operating system to install your HP Multifunction device. Note: Update Drivers in Win Vista
3. Browse Multifunction Drivers.
4. Find HP Multifunction Drivers.
5. Select HP Officejet 6210/6213/6215 All-in-One Basic Software/Driver 4.7.0 Windows 98/ME/2000/XP.
6. Download HP Officejet 6210/6213/6215 All-in-One Basic Software/Driver 4.7.0 Windows 98/ME/2000/XP. Note: you can update all Drivers automatically with RadarSync (Freeware) or DriverScanner (Shareware).
7. Install HP Officejet 6210/6213/6215 All-in-One Basic Software/Driver 4.7.0 Windows 98/ME/2000/XP.
8. Restart or reboot your computer to finish your driver installation. Note: you can backup your computer drivers before updating.
Sep 02, 2010 | HP OfficeJet 6210 All-In-One InkJet...
HP Officejet 6210 All-in-One - Conformation Page
yes
press setup
pres 2 and then press 1
this seletcts print report and then select Fax Report setup.
press and scroll to the to the report type you want.
press OK to select the report
Jan 08, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Using an HP All-In-One of Fax Product on a DSL Phone System
Have you tried a different number.. It almost sounds as if the fax maching you are calling is turned OFF. You might try a different fax number that you know to see if the results are different. Were there filters provided for the VOIP devices?
Nov 22, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Cannot send out fax
Please check the following document which would help you to fix the issues regarding the fax issues.
http://h10025.www1.hp.com/ewfrf/wc/genericDocument?lc=en&cc=us&docname=bpu02151
Regards,
Sagarjd
Nov 21, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Setting up fax with modem
try to used the two conductor cable that came with the printer itself.
- at the same time ask for a filter from your phone provider
- the printer should be direclty connected to the phone walljack
- if you have all this kind of set-up you will be able to recieved faxes now..
send comment/feedback fo furthere troubleshooting...
Aug 30, 2008 | HP OfficeJet 6210 All-In-One InkJet...
HP OfficeJet 6210 Error Code 392
Error 392
Unable to complete the handshake.
*Try to send the fax at a different time when telephone line conditions have improved.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpu02549&cc=us&lc=en&dlc=en&product=421991
heres the link for all other codes listed with your hp
yes there depends on system you have the fax can go threw after the answering service ended
May 07, 2008 | HP OfficeJet 6210 All-In-One InkJet...
HP 6210 using double paper?
Try cleaning the rollers (especially in the back door). It stopped mine from jamming. Hope it will stop the double paper thing!
Apr 15, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Owners manual for HP OfficeJet 6210 All-in-One
If I give you the link to download a HP OfficeJet 6210 All-in-One manual then I'd say thats FixYa
Nov 20, 2007 | HP OfficeJet 6210 All-In-One InkJet...
HP OfficeJet 6210 All-In-One InkJet Printer Logo
44 people viewed this question
Ekse
efs_perpends
efs_perpends
