SOURCE: string peg required for washburn d10b
http://www.stevesmusiccenter.com/EZPeg.html
A new type of peg that makes it easier to change strings!
Either that or most guitar shops stock string pegs, Just ask at the counter .. .If they don't have them and can't get any in then they are not a real guitar shop in my opinion
SOURCE: broken shaft pot on electric guitar
Yes, get a replacement pot at most guitar centers.
You need to match the electrical resistance and the "Taper" as well as the physical shaft size, etc.
You will need to be able to solder the leads to the replacement.
Suggest you take a photo of the inside wiring for reference in restoring.
SOURCE: Both the E and A strings
The neck may require adjustment, but would recommend taking it to a luthier or using a guide like raeguitars to talk you through it. Depending where it is on the fretboard that buzzes, the nut may require replacement/adjustment. I've had all these problems in the past and the above tutorial helped me fix all of them.
SOURCE: We need to replace a broken tuning peg for a
Almost any guitar store would have this and any Luthier would likely have a replacement.
Washburn is a name brand so it should be easy to find the replacement.
