SOURCE: norcent not working
We have ten LT-2722 with similar power problems, at beginin the monitor turn on and off after few minutes or hours, then no turns on at all. But the problem is not at the Power Board, is a bad contact or damage in a integrated circuit U403 (GM1501-BD) at the Main Board, unfortunatelly this IC´s pins are unaccessibles so you must replace the all Main Board (Part Number CBPFF84KMGNCT)
Good Luck.
SOURCE: I need a replacement for the remote to a Norcent
Try website like Remotes.com to buy the original remote.Guarentee it the tv model original remote,warrenty for one year too.
SOURCE: Have no power on my norcent LT-4247 lcd tv?? Cord is fine
Verify the outlet, check out the main fuse in the power supply, check for bad caps, cold solder joints, etc.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Please post back what you find.
SOURCE: please i need manual for
Make sure the power cable is plugged into the T.V. and the wall outlet. If it still doesn't power on try a different outlet. If that still doesn't work then there might be a problem on the board that needs repaired.
SOURCE: i have a norcent 37 no picture model LT 3751 BUT
Hello: This can be caused by several issues.
One is bad capacitors on the power supply not allowing sufficient power to the inverter or a bad inverter board.
2. Bad T-Con board, it is used to control the Display. If the back lights are lighting up then you may have a bad t-con board. If the screen is dark meaning no light, then you may have a bad inverter board or problems in the PS..
