Freezer ice and food defrosted, refrigerator warm but the food in crisper frozen
Whirlpool refrigerators as well as the other brands that fall under the corporation most like at some point within the first five years will stop cooling and freezing, and the sould you here will be either a humming follow by a click or in some cases just the click alone. This is caused by the start device on the compressor. The relay part of it has basically burnt, fell apart inside, however you want to describe and is not passing the power to the compressor to come on. To access this pull the refridgerator out from the wall, and first and foremost unplug it. Once that is done remove the lower panel, sometimes cardboard sometimes metal which is held up by a few quarter inch screws. Place to the side and located the compressor. The box on the side is start device, it will have 2 or 3 wires going to it, most of the time red and white respectively. Also they maybe a black box thats connected to the start device and sits horizontallty. Thats the capacitor. Keep that if your going to do the repair yourself. I recommend doing it because its very easy and will save you alot of money. You can buy this part at www.repairclinic.com or at www.apdepot.com just be sure to have your make and model number handy
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
SOURCE: Jenn Air side by side refrigerator Model
Normal
0
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-fareast-font-family:"Times New Roman";}
The fridge gets its cold air from the freezer through a vent(damper)
between the freezer and fridge.The fan in the freezer blows air through it.
Make sure this fan is running. You may have to hold the door switch in for it
to run. There is a flap you adjust with
the fridge temp. control. Make sure it's opening and closing when you adjust
the fridge temp.
The problem could be the electronic control if
you have one or the mechanical linkages.
If the evaporator coils behind the back panel of the freezer
are icing up because of auto defrost failure that will stop the circulation of
cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In
most newer models the timer has been replaced by an electronic control board.
If the heater and thermostat are ok it’ll be the control.
